Results 1 to 2 of 2
Thread: Wood +Glass+Tile Cnc
    May 2007
    Cool Wood +Glass+Tile Cnc
    Does anyone know of a machine that will do wood projects as well as tile and glass etching,a combo would be nice!!!!
    Jul 2005
    You need to consider doing tile and glass etching using a different method that rotary cutting. For glass/tile you need diamond bits that spin at 50,000 rpm or more. Etching glass is better done if you cut a stencil with a vinyl cutter, stick it to the glass and sand blast etch the design. There are also some photo resist blast stencils to do fine detail or even halftone photos. Same with tile. Even wood can be done with the sandblast method but works better with CNC routers. The media is so dramatically different that building one machine to do both would be not be practical.
    The sand blast method is faster, cheaper and yields consistant results. Google sand carving for more info. You can even do depth carving to give dimensional effects on thicker glass.
    Picture of sand carved glass and CNC routed wood tray.
    Attached Thumbnails Attached Thumbnails Wood +Glass+Tile Cnc-maloufdecanter_celtictray.jpg
  1. Gibbs lathe, cant generate a process tile
    By naytep in forum GibbsCAM
    Last Post: 08-24-2007, 10:45 PM
  2. Cutting Ceramic Tile τΏτ
    By lockeyone in forum Hobby Discussion
    Last Post: 01-07-2007, 11:50 AM
  3. Anyone cutting carpeting or tile?
    By Matt B in forum General Material Machining Solutions
    Last Post: 12-27-2005, 12:27 PM
  4. Printing on hard surface tile?
    By jeffterm in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-01-2004, 06:32 PM
  5. Anyone Cutting Carpet of Vinyl Tile?
    By Matt B in forum DIY CNC Router Table Machines
    Last Post: 09-29-2003, 11:37 AM
