Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 01-09-2008, 09:57 AM
Blanshan91 is on a distinguished road
Engraving Advise Needed
I would like some help on what tools I should use for engraving. I have a small CNC mill which can run at 3600RPM. I use the RhinoCam software to create the toolpaths/G-code. For engraving text, what would you recommend for engraving bits? I have tried using dremel bits with a ball nose but I either break them or the text is sloppy. My engraving is always done on a flat surface so nothing fancy.
I generally use 6160 aluminum but will be doing some mild carbon steel too? If you have help, please let me know.
Old 01-09-2008, 10:13 AM
*Registered*
Mike Stevenson is on a distinguished road
Use a one flute Carbide Engraving tool. Most machine shop suppliers stock them.
Old 01-09-2008, 10:20 AM
bclark6716 is on a distinguished road
another good resource is www.2Linc.com. nice selection at reasonable prices.
Old 01-09-2008, 10:32 AM
What do you recommend for shape of cutter for general text?
Old 01-09-2008, 11:23 AM
diecutter is on a distinguished road
I'm assuming you are engraving in steel since you are using a mill. Use a 60 degree included angle split point (single lip) carbide cutter with about 25 degrees relief clearance , 5 degrees side clearance,and 10 degrees back clearance. 3,600 rpm is a little slow, but doable; just reduce tool feed to compensate. Antaresinc.net has a wide selection of cutters and lots of information on choosing the right one for your situation.
Selecting the right CNC Mill - Advise needed Rich05 General Metal Working Machines 38 05-24-2007 09:18 AM
Newbe - Calabration advise needed deleteallusers G-Code Programing 2 05-04-2007 11:19 AM
Advise for Heidenhain needed Oopee General CAM Discussion 20 08-04-2006 11:16 AM
Cleaning Up vector files for CNC Engraving? Advise Please Bretto General CAM Discussion 27 07-25-2006 03:26 AM
Advise Needed glbreil General Metalwork Discussion 10 04-03-2006 06:13 PM
