Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 12-18-2007, 06:36 AM
pmurdock is on a distinguished road
How to make dial indicator face? Technique? Etch/Engrave/Silk Screen/laser?
I'm working on a compass design that requires a 360 degree series of lines and numbers to be engraved/etched/???
I see this on a lot of dial indicators, etc.. What technology is actually be used to make precision lines and numbers on the faces of dial indicators? Ideally a black background with white text would be very easy to read. I'm just not quite sure what technique is being employed.
cheers,
Paul
Old 12-19-2007, 10:20 AM
engraving small
Ok.. so I think I've discovered how it is done... The only thing I'm not sure is whether it is possible or not on a Haas VF-2.
Use an engraving bit 30 degree with a 0.001" tip
The total diameter of the dial is 3/4".. So the indicating lines are 0.006" apart with a 0.002" line width.. does this seem feasible and particularly on a vf-2?
cheers,
Paul
Old 12-19-2007, 12:07 PM
maxbela is on a distinguished road
Hi Paul,
I had a similar problem a few years ago and ended up etching it using a photo resist.
I contacted a company that etched circuit boards for info on which resist to use.
There is a forum here, I think, about DIY circuit board making.
Like laser marking etching applies no physical force to the workpiece which could be a factor if you are using thin material.
regards Max
Old 12-19-2007, 12:24 PM
Originally Posted by maxbela View Post
Hi Paul,
regards Max
That's one option I had considered... Did you have someone make a plate mask with the fine details and just did the exposure and etching yourself?
cheers,
Paul
Old 12-20-2007, 06:22 PM
graver1 is on a distinguished road
compass dial
I looked up the Haas VF2 and I would guess there isnt much you cant do with it. For this I would cut a 5 or 10 to 1 master pattern with all the lines and letters, and find a trophy engraver that has a small diamond drag pantograph. They probably already have a cnc panto graph that will do the same thing. Find some black anodized aluminum blanks and your there. New Hermes is a good source. Good luck. LL.
Old 12-20-2007, 08:41 PM
Basically yes. I drew it up about 20 times size, had it photographed and reduced to give me a mask, exposed it using a vacuum frame.
regards Max
Old 12-20-2007, 08:52 PM
Update
Thanks for all the input... I've got some engraving bits on the way (found at Bits & Bits) and will try engraving with these on some sample pieces to see what the results look like.. I'll try go get some pictures posted to give an idea of what it looks like.. If it doesn't work out I will go the etching route.
cheers,
Paul
silk screen machine Mr. midnight Hobby Discussion 12 04-27-2010 09:31 AM
Homemade Screen Printer/Silk Screen Sbthomas13 Machine Created Art 20 02-13-2009 07:35 PM
dial or test indicator for squaring/leveling linear rails? margni74 Calibration & Measurement 3 09-18-2007 08:45 PM
Dial indicator hkrok Product Announcements & Manufacturer News 1 08-16-2007 08:49 PM
what does dial indicator use to measure? cnc2k General Metalwork Discussion 9 07-16-2005 08:20 AM
