Results 1 to 3 of 3
Thread: Hold-Down Mat for very small items
    Nov 2007
    Hello, does anyone have a suggestion for a tack mat to use for very tiny engraved items (1"-2")?
    We currently have a couple of Roland EGX-30's. We purchased another used one about a month ago, and it had this fantastic white mat on the engraving table. No slipping, flipping, etc. The problem is, it gets worn after only a couple days, and I don't know where to purchase any more. I can't find it anywhere!
    The mat is about 1mm thick. It's not sticky, but it sticks to itself. It's sort of a foam-type material. If anyone knows where I can find more of this stuff, please contact me.
    Also, we've tried other options, the multi-mat, for example. This definitely did not work for us.
    Any other suggestions out there as to what other folks use to keep their tiny engraved items held down, I'm all ears!
    Thank you in advance.
    Jen
    Jan 2005
    You might be able to use double stick tape, like for holding carpet in place. I've had fair luck with that and I've done the plastic tags with another type tape that only has adhesive after you pull the backing off.
    For higher volume production how about a vacuum table?
    Sep 2008
    UK
    Try here...
    http://www.dycem-ns.com/reels.php
    It sounds like exactly what you're after..
    Mart
  1. Need advice on bench top items
    By Mousehouse in forum Benchtop Machines
    Last Post: 03-17-2007, 05:28 PM
  2. Should I buy these Sanyo items?
    By dar303 in forum Servo Motors and Drives
    Last Post: 03-16-2007, 03:40 PM
  3. Shipping large items to Australia
    By Hasher in forum Australia, New Zealand Club house
    Last Post: 01-15-2006, 01:40 AM
  4. How to hold small workpiece?
    By kad2kam in forum General Metal Working Machines
    Last Post: 07-29-2004, 02:08 AM
  5. Handy Little (Electronic) items
    By Al_The_Man in forum General Electronics Discussion
    Last Post: 06-19-2004, 10:17 PM
