| Engraving Machines Discuss Engraving Machines here. |
I have some of the Rowmark Ultramatte reverse engraving acrylic plastic. http://www.rowmark.com/rotary/ultra-...es_reverse.asp Basically it's a 1/6" product that is clear on the front and black (or many other colors) on the back. You reverse engrave the colored side and then use acrylic paints to paint the engraving. Pretty slick looking stuff once it cut and painted. I called Rowmark to ask about typical cutting speeds and motor speeds but they didn't know or have any technical data. Usually this sort of material is cut on an engraving machine and I guess there must not be motor speed and feed rate settings? Just a guess. I am using my small cnc machine to reverse engrave with a single flute 60degree carbide engraving bit. Did one short test engraving yesterday and it came out ok, not awesome, but ok. I have my cnc machine tool running through a Variac, so I can slow the motor down from it's 30,000 max rpm. Not ideal, but it works ok on plastics. Long winded post I know: Just wondering if anyone out there has used this material and has some suggestions on feedrates and motor speed settings? Thanks |
| I used a Variac to slow my motor speed way down. Need to get a motor speed control unit instead of using the variac, which reduces the ac voltage to the motor. Anywho, Feedrate of 20 in Mach3 worked out real good with the Rowmark material. Cutting depth of .10 to .15 looked good Made several faceplates for guitar amplifiers and theay all came out great. |
| Reverse post in V9 | pimpbike | Mastercam | 0 | 09-12-2007 04:19 PM |
| Reverse | frankg521 | Mach Mill | 3 | 08-05-2007 10:08 PM |
| Reverse engineering | quadbob | PTC Pro/Manufacture | 2 | 04-27-2007 07:54 AM |
| Reverse? | UKRobotics | General Metal Working Machines | 3 | 09-11-2006 07:20 PM |
| Reverse CNC | adwsystems | General CAM Discussion | 4 | 05-16-2006 08:05 AM |
