| Engraving Machines Discuss Engraving Machines here. |
I have a quantity of circular stainless steel discs that I need to do a simple engraving onto the face. The max rpm I have is 3500 from a Syil CNC X3 mill & currently I have no flood coolant. I've experimented today with what I have, a 1mm HSS ball cutter & a can of WD40 with surprisingly good results, tool held in the original X3's drill chuck ! Having just got the machine, & running several projects at the same time, I'm suffering a severe case of information overload. I have the £cash but I don't have the time to spend on the learning curve to discover which tool & holding system is best suited to this type of work. Can anyone recommend anything available in the UK ??? I'm also after a range of base colour engraving paints, a Google search throws up nothing but another learning curve. What's the best engraving paint available in the UK ???? |
| What is the spindle taper of that machine? An ER-20 collet holder and a "D bit" (engraving tool) should work real well, use a cutting oil like rapid tap or just an air blast to clear the chips. A solid carbide spot drill might work well, or the small ball nose end mills, just go solid carbide because HSS will be pretty flexible.
__________________ Live free or die |
| Definitely get a collet holder, a drill chuck is not going to give you the best results and with a "D" bit will probably cause a lot more breakage as well. 3500 RPM isn't exactly optimal, but in stainless and with the right bit you can probably get away with it with reasonable results with a little experimentation. Carbide "D" or "V" bits of a wide included angle would be a good starting point. Small ball mills might work fine, but I don't know how long each one would last, especially without constant coolant flow. You might try a water-based coolant as well, I have had better luck with those than oil-based for engraving. If you need to do a whole lot of discs, simplest and quickest way might be to do what some folks have done and get one of the little high-speed Proxxon die grinders or the like and mount it to the side of your Z head for the duration of your engraving needs. That will give you the speed if you find you need it or want to speed up a large run. |
![]() Here is a good source for paints...(and other engraving bits) http://www.gravograph.com/uk/ Cheers... |
| we do 99% stainless, and do masses of engraving. the best cutters we have found are "Magafor". uk dealer is ToolEx. not cheap, but Really good. especially "Hard-X" coated ones. 40 deg' we do have 40,000 rpm spindles though. and use oil-mist. you can run slower, but be run fast to maintain accuracy over depth.
__________________ >>>>>>>>>> Made In England <<<<<<<<<< |
Thanks. I'd estimate that over the past few weeks you've saved me at least £300. I was burning out or snapping off £8 a time bits at an alarming rate untill I tried a 50p centre drill. They still snap off or burn out at the same rate, but who cares???? |
#10
| I would use a solid carbide cutter for the stainless. I have a .25 dia. 2 flute solid carbide engraving bit with a 90 deg. angle which I use for most of my engraving. I just wish I had a similar bit in a sharper angle for the engraving work that is on small parts and which has paths very close to each other.
__________________ Regards, Wes |
| Just wanted to know.. | extrem89 | Polls | 2 | 08-28-2007 10:16 AM |
| New and in need of some advice... well alot of advice! | GoonShoes | Bridgeport and Hardinge Mills | 9 | 05-30-2007 08:03 AM |
| Advice requested on getting first mill tooling.. | hotponyshoes | General Metalwork Discussion | 9 | 04-04-2007 11:48 AM |
| Wanted PP! | Hammar | Deckel, Maho, Aciera, Abene Mills | 0 | 12-12-2006 05:24 AM |
| Sieg X3 Z-axis Conversion advice wanted | Bird_E | General Metal Working Machines | 22 | 11-27-2005 09:06 PM |
