Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 07-10-2007, 10:59 AM
srmaietta is on a distinguished road
Best alloy aluminum for engraving?
Hello I am about to purchase some aluminum plate for engraving, and would like to know if there are any better alloys to choose with engraving in mind?
thanks
~Steve
Old 07-10-2007, 10:53 PM
johnmac's Avatar
johnmac is on a distinguished road
I would like to know, too. Is there any way to tell the alloy of a unmarked plate?
Old 08-01-2007, 07:34 PM
*Registered User*
boothie is on a distinguished road
Hey guys,
Don't know about the engraving part but if the end product is to be anodisied then the less additives in the alloy the better. These can cause issues during the anodising and cause an uneven finish and blotchie results. Whenever we machine the stuff we run fast with lots of coolant and for some reason HSS cutters don't grab as much as tungsten.
Boothie
Old 08-01-2007, 07:39 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
thanks
~Steve
I'd say the easiest would be 6061-T6. It cuts nice and the Surface Finishes are excellent.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-01-2007, 08:12 PM
Yes, this is the case. We have a few parts that have text engraved and it comes out very nice. 6061 also anodises very nicely and can be dyed a great variety of colors. One technique we use is to machine the basic shape then anodize and engrave after anodizing. The result is a nice visible text like the picture.
Old 08-01-2007, 09:00 PM
tobyaxis's Avatar
Moderator
Geof,
What Brand of Engraving tool are you using, a Melin Conical Blank 30 Degree Included Angle, or a 60 Degree Mill Drill 2 to 4 Flute???
Toby D.
Schwarzwald
Old 08-01-2007, 09:52 PM
Geof,
It is just a 1/8" dia., 90 degree spot drill running at 10,000rpm and I think on those plates 100ipm. The 1.000 refers to the diameter of the semicircle to give you a sense of scale.
Old 08-02-2007, 06:34 PM
tobyaxis's Avatar
Moderator
What do you recommend for Engraving 316L Stainless?
Toby D.
Schwarzwald
Old 08-02-2007, 08:39 PM
Let somebody else do it .
I detest working with stainless, getting lazy in my old age I guess. I expect trying to engraving might be difficult, the adage take a deep cut and get under the work hardened surface hardly applies.
You are going to have to experiment.
Old 08-03-2007, 12:19 AM
tobyaxis's Avatar
Moderator
Yea, breaking tool tips comes to mind LOL. I will be trying a Mill Drill 60 Degree Point 4 Flute Carbide Coated TiAlN. Some how breaking the skin will be difficult because the depth of cut will be .005. Maybe I'll Engrave a Surface with plus .035 , then try a Finish Ball Mill, and a Spring pass on the engraving. That tool tip is going to suffer some dulling, LOL.
Any other ideas Geof???
Toby D.
Schwarzwald
  #11   Ban this user!
Old 08-03-2007, 12:43 AM
....Any other ideas Geof???
The only other idea I have is a bit far out; diamond bit at a very high rpm. I have no real idea whether it would work but I would probablt be tempted to try it as a last resort.
Old 08-03-2007, 02:09 AM
tobyaxis's Avatar
Moderator
I think your on to something with that idea , but wouldn't a Diamond Chip in 316L SS??? What do you mean as far as RPM, like 10,000 or 20,000???
Toby D.
Schwarzwald
Engraving in anodized aluminum fish09 Engraving Machines 6 08-24-2007 05:02 PM
Engraving annodized aluminum theclive Laser Engraving & Cutting Machines 0 04-03-2007 12:44 AM
rfq on .125 aluminum engraving cncsdr Employment Opportunity 5 01-22-2007 07:34 PM
Determining aluminum alloy type bdrmachine General Metalwork Discussion 4 12-12-2006 09:22 PM
Engraving aluminum...... Tyler Durden General Metalwork Discussion 13 09-16-2006 05:14 AM
