Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 06-26-2007, 03:25 AM
Dingo745 is on a distinguished road
Engraving Plastic Sign Material
I just had my first go at engraving some dual layer sign material, not sure of it's technical name.
I'm very new to cnc so I'm learning as I go.
First I should mention it was trialled on a cnc router, using a 30deg. conical engraving bit with a flat 0.1 end. The router I used has a minimum speed of 11,500 rpm. unloaded. Feed Rate was around 600 mm/min.
Anyhow as expected it was flop. The plastic quickly melted onto the cutting tip.
I couldn't slow the router any more so I tried a water/detergent spray on to the cutter to help cool it down, but also without success.
Can anyone offer some tips on engraving this type of material, or a link to a good source of relevant info.
Thanks.
Old 06-26-2007, 03:57 PM
engraversman is on a distinguished road
engraving plastic
that type of plastic these using
Old 06-26-2007, 05:20 PM
rustamd is on a distinguished road
what about tring to use faster speed(mm/min)?
Old 07-04-2007, 07:48 AM
John Klemmer is on a distinguished road
Your feed rate is too slow. That's a good way to start a fire. Typically you need a tooth load greater than 0.001" (0.025mm) per tooth per revolution. Try feeding in the 2000 to 3000mm/min range. Slow down to improve finish or prevent breaking small diameter cutters.
Old 07-04-2007, 09:21 AM
At the moment the old girl won't do 2000mm/min feeds.
I'm upgrading to a coarser pitch ballscrew to improve speed and accuracy.
I'm also going to try another brand of router that has a minimum speed of 8000 rpm. which might help as well.
All part of the learning process I guess.
Old 07-04-2007, 10:48 PM
*Registered User*
kyfds is on a distinguished road
can it be engraved by a laser engraving machine??
Old 07-05-2007, 04:24 AM
Yes it probably could be done with a laser, but I have a rotary machine.
I built myself a multi-purpose machine and was hoping to be able to some engraving on plastics and other materials.
It was my first effort, so it now needs some refinement of technique and machine.
Old 08-08-2007, 08:42 PM
srmaietta is on a distinguished road
maybe get a variable speed controller for your machine? run the motor at maximum and then use the variable speed control to slow it down, might work to get your rpms down.
Ive got some plastic on order, and cant wait to try it out.. now Im worried about melting!
(crossed fingers)
~Steve
Old 08-11-2007, 09:27 AM
watkins8014 is on a distinguished road
I think thename of the plastic is Traffilite and when ordering you specify black white black or whatever colour preferencies you require
Old 08-14-2007, 11:16 PM
tpworks's Avatar
tpworks is on a distinguished road
Actually it is a co-extruded plastic for engraving. Traffilite might be a brand name.
http://www.artisan-es.com/Rowmark.htm
Tom
...He who makes no mistakes makes nothing! ...
Tom
  #11   Ban this user!
Old 08-17-2007, 10:58 AM
I Stand Corrected, Traffolite Is A Tradename Abit Like Delrin And Acetal
  #12   Ban this user!
Old 08-17-2007, 07:39 PM
tpworks's Avatar
There is a plastic designed for laser different from engraving type also here is a link addressing your problem.
http://www.talkshopbot.com/forum/mes...tml?1180131665
Tom
I need suggestions for outdoor sign material. Glidergider Glass, Plastic and Stone 14 05-20-2009 09:15 PM
2 ply engraving plastic? DennisCNC Engraving Machines 2 05-07-2007 07:37 PM
high performance plastic - bearing material Chris D Glass, Plastic and Stone 6 09-03-2005 07:43 AM
Plastic Sign Material - Where to purchase? edbo68 DIY-CNC Router Table Machines 9 04-26-2005 11:59 PM
