Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 04-22-2007, 05:16 AM
micatech is on a distinguished road
Unhappy Engraving Text
I am using Corel make a faceplate and engrave some text about 5mm high on it. I am using Stick40 font as it is a single pass font.
The problem is that I cannot seem to insert spaces in between the words.
Rather than "this is a test" I end up with "thisisatest"
I have tried using stick40 font in Winword and I get same problem.
Has anyone used a single pass font sucessfully?
Any help appreciated.
Larry
Old 04-22-2007, 11:41 AM
sailandoar's Avatar
sailandoar is on a distinguished road
What process/programs/details are you using.
Corel is the CAD program. Are you generating an output file that is being used by a CAM program to generate the g-code? etc etc
Old 04-22-2007, 04:28 PM
Davidh is on a distinguished road
...I cannot answer the corel question but maybe can offer a solution.
Use Deskengrave, free download program to generate the text as g code or dxf. Do the text with another hit or maybe import it (.dxf)into corel.
Old 04-22-2007, 04:37 PM
paulC is on a distinguished road
If it won't work in WinWord it is proberbly a fault in the font.
Either try downloading the font again or you could swap font of the spaces if you are really desperate. If it is a specialist font it may not even support a space, some don't.
Paul
Old 04-22-2007, 05:49 PM
Generating G Code
I am generating a drawing with Corel, then saving it at HPGL and and then using Mach3's Lazy cam to read the HPGL file to generate the GCode.
Basically all I am after is a decent FONT that I can use for engraving. Stick40 font is great if I can only put spaces in it.
Old 04-23-2007, 02:35 AM
Dtye is on a distinguished road
If You are Useing Mach 3 take a look at the Write program under Wizerds. there some stick fonts there.
Dick
Old 04-23-2007, 06:58 AM
sailandoar's Avatar
So have you tried other fonts to see if they can generate spaces? If so and you want/must use stick40 then perhaps if you have the space be a different font like 'times' or 'courier'.
Old 06-29-2007, 12:50 PM
5S Dude is on a distinguished road
Cool
In Corel after you have typed the text you wish to engrave, I simply click on “Arrange” and use the bottom choice which is “Convert to Curves”. Then continue with your normal processing.
Old 07-01-2007, 01:13 PM
Torchhead is on a distinguished road
Or.......type font in Corel, leave in font format (so later editing is easy) and convert to DXF with full arcs using our DXFTool plug-in for CorelDraw 12 and 13. No convert to curves necessary. Free Time limited demo on our website
tomCAUDLE
www.CandCNC.com
BOB's
Digital THCs
DXFTool Software
Complete Electronic Packages
Stepper & Servo Systems
Hand Controllers
Old 07-26-2007, 03:38 PM
DS420 is on a distinguished road
Generate G codes directly from Corel Draw
You can generate G codes directly from Corel Draw, if you want. Can provide information, if you are interested.
  #11   Ban this user!
Old 07-26-2007, 03:43 PM
Stick40 font
Where do I find out more about this stick 40 font?
  #12   Ban this user!
Old 07-29-2007, 01:22 AM
johnmac's Avatar
johnmac is on a distinguished road
DS420, How do you create G code from Corel Draw? What version is needed?
John
Text Engraving prob?? NardisAmps Mach Software (ArtSoft software) 9 04-22-2007 10:55 PM
Text engraving with Ajax cnc Ed VanEss General Metalwork Discussion 0 09-21-2006 12:30 PM
engraving text on Ajax Ed VanEss General Metalwork Discussion 0 09-19-2006 12:48 AM
Help using V19 for engraving Text rustyolddo BobCad-Cam 4 03-10-2005 12:54 PM
Text engraving & fit to arc? dk1machine BobCad-Cam 4 07-06-2004 02:48 PM
