Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 02-26-2007, 09:54 PM
srmaietta is on a distinguished road
engraving anodized alum
hello all, I am planning on engraving some aluminum panels, anodized dark blue. and or black. I will need letters ranging from .125 up to .250 tall, just deep enough to expose the shiny metal. I plan on using rotary bits, but would like to try diamond dragging as well (if the bits are reasonable -$)
any tips on depth/speeds, bit angles etc. basically I need to know where to start my experimenting. I have a laminate trimmer 30k rpm.. should I get one of the cheap router speed controls?
And with the diampnd drag, how do you set the drag pressure - spring loaded tool holders? or do you set the Z to go say .002 -.005 below the surface?
diy cnc router, mach3. want to get the vectric software.
newb here thanks for any tips or starting points!
~Steve
Old 03-01-2007, 10:59 AM
5S Dude is on a distinguished road
Thumbs up
~Steve
Hi Steve, I used the diamond drag method utilizing a 1/8 shank diameter diamond dressing tool from our grinding dept. and mounted it into the spring loaded tool holder. Worked great!
Old 03-01-2007, 04:37 PM
Thanks 5S dude for the reply. What spring loaded holder are you using? Should I worry about my non lockable spindle messing up the engraving? Does the drag process put heavy side loads on the spindle bearings that I should worry about in the long run?
thanks
~Steve
Old 03-02-2007, 12:04 PM
Thumbs up
thanks
~Steve
Hi Steve,
I use the spring loaded engraving holder from “2L inc. P.O. Box 105 Hudson, MA 01749 (978)567-8867” http://www.2linc.com/engraving.htm
It works awesome and with the adjustable spring tension there is very little side load if any. I typically program a Z-.007 to .010 deep with a feed rate of F50. to F100. inches per minute and the engravings come out razor sharp. On my V2XT, I place the spindle in neutral and program a spindle speed of S750 because there is a safety interlock that won’t let the X & Y axis move with out a spindle speed.
Old 03-02-2007, 04:23 PM
thanks for the info man!!!!!
ill have to look for the spring loaded tool holder.
cant wait to get going!
~Steve
Engraving anodized aluminum - color fill? Neil_J Hobby Discussion 25 09-16-2008 10:11 PM
Laser etching anodized aluminium Fred Nerk Laser Engraving & Cutting Machines 14 08-02-2007 09:51 AM
Milling Alum. Smackre General Metalwork Discussion 6 11-22-2006 08:10 PM
Anodized Aluminum Round Rod - Best Place To Buy It? nlh General Material Machining Solutions 0 12-02-2005 10:54 AM
Alum Angle Ursine DIY-CNC Router Table Machines 9 05-13-2005 07:49 AM
