Results 1 to 5 of 5
Thread: Engraving and V Carving.
    Registered Tweakie's Avatar
    Nov 2009
    UK
    Thanks to Zasti for the ‘heads-up’ on this one Fórum - a new, free, engraving program which supports ‘V Carving’ F-Engrave
    The program works just fine with WinXP and the GCode produced is excellent using Mach3.
    This is just a test sample, to try it out, which, I think, shows that it can produce results to match the commercial VCarve programs.
    Tweakie.
    Attached Thumbnails Attached Thumbnails Engraving and V Carving.-dsc01139a.jpg
    CNC is only limited by our imagination.
    Dec 2011
    Going to look into this more when I get home.
    Nov 2009
    UK
    Hi Guys,
    The more I try this F-Engrave software, the better it gets.
    It also supports relief V-Carving and is just so easy to use - top marks to Scorch for an excellent, free program.
    Tweakie.
    Attached Thumbnails Attached Thumbnails Engraving and V Carving.-dsc01142a.jpg
    Aug 2007
    That looks good.
    We all live in Tents! Some live in content others live in discontent.
    Nov 2009
    UK
    Quote Originally Posted by Boots View Post
    That looks good.
    Thank you Boots, most kind of you to say. I am learning as I go.
    (Incidentally, for others that follow, this free software also contains a number of single line (stick) fonts which are just excellent for normal engraving work).
    Tweakie.
    1. Engraving - Carving Photographs
      By Tony Mac in forum Vectric
      Last Post: 05-08-2011, 04:40 PM
    2. Carving (engraving) on a Taig!
      By ecope in forum Taig Mills & Lathes
      Last Post: 05-27-2008, 11:13 PM
    3. Engraving and carving stone, I'm Confused
      By foamcutter in forum General Material Machining Solutions
      Last Post: 08-03-2006, 08:54 AM
    4. Questions About Carving And Engraving Pictures
      By bradyfb in forum Carken Products (Deskam, DeskCNC etc)
      Last Post: 06-27-2006, 08:37 AM
    5. Image Engraving/Carving bits
      By Dman in forum DIY CNC Router Table Machines
      Last Post: 04-16-2005, 05:41 PM
