Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 12-14-2011, 04:13 PM
helpmeout is on a distinguished road
abs plastic
Where can a person order some abs plastic sheet about 2ft.x 2ft. to use for some name tags. white outer and black second layer about 1/16 inch thick. have called every where in little rock Ar. and no such luck. is this stuff this hard to find.
Old 01-09-2012, 12:03 PM
Tweakie's Avatar
Tweakie is on a distinguished road
Have you tried Mr Plastic ?? Industrial Plastics, Rod, Sheet & Tube Distributor - Mr. Plastic
We have them here in the UK - you may have to buy whole sheet size rather than 2 x 2 though.
Tweakie.
CNC is only limited by our imagination.
Old 01-09-2012, 08:57 PM
lwill's Avatar
lwill is on a distinguished road
Johnson Plastics - Your Premier Distributor of Laser and Rotary Engraving Products and Sublimation Supplies
Old 02-27-2012, 08:00 PM
riverboat is on a distinguished road
You might take a look at
Plastic Sheets and Materials for Laser and Rotary Engraving
Newbie- Can you use ABS plastic to do VF? kustomjs Vacuum forming, Thermoforming Etc 8 09-08-2011 07:59 AM
PLASTIC STRAW/PLASTIC EXTRUSION PARTS/T8 TUBE shayla Product Announcements & Manufacturer News 0 07-21-2009 03:35 AM
Need Help!- Name this plastic TMaster Glass, Plastic and Stone 7 07-12-2008 10:58 PM
My Plastic CNC alecu7 Open Source CNC Machine Designs 5 11-16-2007 12:44 PM
Using plastic? ZipSnipe Diemaking and Diecutting 4 01-29-2007 09:21 AM
