Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 10-24-2011, 10:51 AM
splante is on a distinguished road
Suda VG1325 Engraver
A manufacturer I am working with can only engrave upper case True Type Fonts on their Suda VG1325 (no lower case). They use Bobcad software to import their files and then TYPE3 Version 4,2,0,0 Build 003 to create the engraving file. They want to expand the number of fonts they can effectively engrave and they like the single line Fonts because they engrave quickly and efficiently. Does anyone have a solution for this? Is there a Vision Numeric font library available? Thank-you for your patience, I am new to the industry.
Old 11-25-2011, 02:32 AM
Alex jumhone is on a distinguished road
Smile laser machine engraving in all kinds of materails
a laser machine linked with computer by usb can help you engraving all kinds of materials except matel material as you wish, and CNC machine be suitalbe to matel materials, if you show more information, i think i can help you.
Old 11-25-2011, 12:27 PM
muqtadir is on a distinguished road
Splante
You can download DEMO version of VCARVE Pro 6 and can use all the winodws fonts and then save toolpath as you like.
SUDA SL9060 with MPC03 buddhafragt Laser Engraving & Cutting Machines 4 08-25-2011 03:53 AM
SUDA ST1212S CNC ROUTER HELP!! bayeng Chinese Machines 1 05-19-2011 03:41 AM
Need Help!- Bearing Failure on SUDA SD1208 joeyg Commercial CNC Wood Routers 0 07-02-2009 04:43 PM
Need Help!- SUDA SL4030 LASER ENGRAVER SHARE EXPIRIENCE ANDREAS1968 Laser Engraving & Cutting Machines 0 03-02-2009 05:39 AM
Need Help!- Cooling liquid for SUDA SD1208? joeyg Commercial CNC Wood Routers 4 12-29-2008 06:56 AM
