Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 10-12-2011, 06:16 PM
jmalmeida is on a distinguished road
Engraving machine
Hello!
Anyone kowns if the VHF CAM 220 machine can engraving stainless steel?
Thanks,
José
Old 10-13-2011, 07:13 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Maybe lightly, but any machine built in the style of a router will struggle with SS because the rigidity may just not be sufficient for the material hardness.
Tweakie.
CNC is only limited by our imagination.
Old 10-14-2011, 12:16 PM
Tweakie, thanks for your reply.
Could you tell me the type of machine to engraving SS?
Best regards,
José
Old 10-14-2011, 10:42 PM
luckydoglele's Avatar
luckydoglele is on a distinguished road
Best regards,
José
it is better way you need to use the special tools for SS, what's the thickness you want to work with?
plasma machine also can cut.
Old 10-15-2011, 01:17 AM
Tweakie's Avatar
Best regards,
José
If you take a look at the Gravograph site that should give some idea of the machines used for stainless. Obviously cheaper (clone type) machines are available from other makers but you should to look for something substantially constructed with plenty of rigidity, particularly as far as the spindle is concerned.
Tweakie.
Old 10-15-2011, 04:15 PM
I want to engrave 0,3 mm Stainless steel and 3 mm Steel depth.
I already have a IS400 Gravograph's machine but the hardest metal I can engrave is brass. The spindle has got only 70 W power.
Best regards,
José
Looking for an Engraving Machine beeman_mccheyne Engraving Machines 2 06-03-2011 11:23 AM
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 03:54 PM
New Machine Build- Sell CNC router ,CNC engraving machine ,CNC laser machine kelvinguo CNC Machining Centers 0 10-07-2010 12:39 AM
