Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 10-12-2011, 03:05 PM
barty72 is on a distinguished road
Gravograph vx serial connection to PC
Hi All,
I'm helping out a friend who is currently using his Gravograph VX controller to control the gravograph engraver from 1988 with a windows 3.11 PC with a serial connection (25pin to 9 pins on windows 3.11 pc). The data is received on the graphograph controller by DG CAD 1.09 and is working fine. (seems to be a standaard 25pin to 9 converter)
I'm trying to convert this system to windows 7 laptop. However when I connect the serial connector, "a bit" is received by the DG CAD program, so in this case the receiving stops. I have verified this also happens when the laptop is in the windows start mode "Press F8". It seems to be a hardware issue and nothing is seen with a serial port analyser when connecting the cable in windows 7.
Does anyone has the 25 serial pin layout for the gravograph vx controller and/or have other suggestions.
Xander
Tags
gravograph vx, serial cable
Need Help!- 00PC Serial Connection Stupidav Fanuc 3 02-04-2011 11:11 PM
Serial connection Mvu Commercial CNC Wood Routers 2 01-15-2010 08:03 PM
Need Help!- Old Gravograph vx killerspost Engraving Machines 1 10-10-2009 10:06 AM
Need Help!- Retrieving TNC 145 via serial connection A.A Bridgeport and Hardinge Mills 3 03-20-2009 08:07 AM
Bandit Serial Connection Chris64 General Metalwork Discussion 34 01-09-2008 05:59 PM
