Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 10-04-2011, 09:32 PM
Carcegen is on a distinguished road
Can Vacuum metalized ABS be engraved?
I'm a newbie here with a new product being developed. This is a small consumer product that is molded in black ABS and then vacuum metalized for a mirror chome finish. We'd like to engrave specific designs (2" x 1") on one of the parts. The idea would be to etch or engrave away the chrome, revealing the black ABS underneath. How can we do this successfully? Would a laser engraver be able to do intricate designs on a chrome plastic surface? Would the plating flake at the edges? Would a standard tool engraver work better? I had heard that laser's hate mirror surfaces. Would this be a problem. Thanks for your help!
Old 10-05-2011, 09:55 AM
mcphill is on a distinguished road
I can't answer you definitively, but I think you will not be able to engrave chrome with a CO2 laser. A YAG or a fiber laser may work. Take it to a good shop in your area and they should be able to see what would work for you.
Your designs can be VERY intricate, and the edges should be clean cut and avoid flaking. That said, you won't know until you try! Can you get a sample of the substrate and coating you will be using as a sample and have a shop work with that to test what is possible?
CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
Old 10-05-2011, 05:51 PM
packrat is on a distinguished road
Most "chrome" plastic is vacuum metalized with aluminum. I would try using an engraving bit, but, if the lines are too close together the metalizing may lift off of the plastic in that area.
Pewter - can it be Laser engraved? bubbs64 Laser Engraving & Cutting Machines 3 03-17-2010 05:55 AM
My first engraved sign GeeksGoneBad ArtCam Pro 9 02-21-2010 06:57 PM
has anyone engraved silicon rubber? geekinesis Laser Engraving & Cutting Machines 4 12-09-2009 07:46 AM
Need Help!- Painting engraved text Photon713 Metal Finishing and Plating 6 07-14-2009 07:12 PM
Need Help!- lines appear on engraved bmp SHADOW042 Laser Engraving & Cutting Machines 1 02-04-2009 05:55 AM
