| Engraving Machines Discuss Engraving Machines here. |
Hi, need some expert help on engraving traffolyte! We have a small desk top cnc router, gantry type. We are running Mach3, CAMBAM, and design in AutoCad. The main use for the CNC is to produce Traffolyte front labels for control panels. Everything works well except we seem to have pretty bad results when it comes text. The size of text that we are trying to use are 5-6mm. I have tried micro end mills, v-cutters, i have tried different free stick fonts types, i have tried Stickfont v1.1, CamBam fonts, I am aware that most fonts availible are not single line. I am also considering do we need a floating head spindle arangement, to eliminate any differences in bed. What I am hoping is that some kind person could give me a few pointers in the right direction, ie font type (nothing fancy, these are electrical control panels, and we are happy to purchase the right font), the tool type, machine setup (spindle speed, depth, speed etc) Many Thanks in advance Spence |
| Hi Spence, It is a common problem and the only real answer is to buy a software package with engraving fonts. There is just not enough free stuff for engravers. I found StickFont OK up to about 10mm beyond that it gets ragged but you must machine or level your table before engraving anything. After a number of years struggling with this issue I finally saved up enough to purchase Vectric software and this has made life much easier. Tweakie.
__________________ CNC is only limited by our imagination. |
Hi, Are you cutting too deep For 5mm fonts, the truncication of the cutter should be 12% of this eg 0.6mm If it is deep you tend to get ragged cuts Traffolyte is approx 0.010ins deep before hitting the soft centre on 1.5mm laminate Is there any play in the spindle, bearings etc The flatter and more level the bed the better the quality of engrave, unless you have a floating cone to compensate Traff is a little uneven, so I always use a floating cone From my experience the software will improve the resolution of the cutter bit like backlash compensation. My preference is sort the former before buying expensive software |
| Newbie- ST-30 problems????? | roddyf | Haas Lathes | 1 | 11-17-2009 10:30 AM |
| Need Help!- looking for laser engraver to engrave traffolyte | dougdv | Want To Buy...Need help! | 1 | 06-04-2008 09:28 AM |
| Big Problems | jeepcj776 | Commercial CNC Wood Routers | 6 | 03-30-2008 03:06 PM |
| Newbie- problems | b_rant | Vacuum forming, Thermoforming Etc | 1 | 02-08-2008 10:04 AM |
| G2 Arc problems | CharlesM479 | G-Code Programing | 8 | 03-01-2007 06:48 PM |
