Results 1 to 2 of 2
Thread: no laser
    Dec 2007
    no laser
    My 60 watt Chinese laser engraver has no laser output. How can I test it to see if it's the laser tube burned out or no power going to the tube? Is the voltage to the tube DC or AC? What is the normal range of voltage?
    Registered Tweakie's Avatar
    Nov 2009
    UK
    Hi Gary,
    The voltage to the tube is DC and it is around 18,000 Volts. There are dangers to life with high voltages like this so please be extremely careful if you do devise a method of testing or measuring it.
    Perhaps connecting a spark gap (3mm or so) across the tube then a short press of the test button would provide a visual indication of high voltage present.
    Tweakie.
    CNC is only limited by our imagination.
  1. wklaser(Gweike laser) new laser engraver display
    By tina in forum Product and Manufacturer Announcements
    Last Post: 09-21-2011, 07:20 PM
  2. Need Help!- CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser
    By vksingh in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 07-01-2011, 11:52 PM
  3. Cost-effectective 445nm laser for laser show
    By cni in forum Product and Manufacturer Announcements
    Last Post: 12-20-2010, 02:01 AM
  4. New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 03:44 PM
  5. ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS
    By oliver9866 in forum Product and Manufacturer Announcements
    Last Post: 10-17-2008, 11:17 AM
