| Engraving Machines Discuss Engraving Machines here. |
Hello to everybody I have builted my first cnc and I need help for my stepper motor calibration with Mach3 2 NEMA34 Stepper Motors 4.2 AMP 637 oz/in, 1.8 degree, 8 Wires 1 NEMA23 Stepper Motors 2.8 AMP 254 oz/in, 1.8 degree, 8 Wires My ball screw have 16 MM - 5 MM pitch I have tried different value in motor tuning window but with the Z axis I have only nose and vibration if I turn my ball screw by hand everything is running free Thanks |
| The set up procedure for Mach3 is set out in both the manual and the settup instructions available for down load on the Artsoft website. You need to start with low values of speed and acceleration. If you demand too much torque from the motors they stall and you get a nasty buzz. It is also necessary to have some load on the motor as they don't necessarily like running unloaded at certain speeds. You also need to take into account that the use of micro-stepping drastically reduces the available torque so try and use full step if possible with gearing if you are looking for high accelerations and traverse speeds. Try the set up procedures in the manual as this may sort out your problem if not then post the results of following the set up . Hope this is enough to get you going - Regards - Pat |
| Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A | guy2b1 | DIY-CNC Router Table Machines | 16 | 03-08-2011 05:50 AM |
| Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board | wf1318 | Stepper Motors and Drives | 2 | 07-25-2010 02:19 AM |
| Integrated stepper motor? with built-in stepper motor driver | uirobot | Product Announcements & Manufacturer News | 0 | 06-07-2010 03:59 AM |
| Beltdrive-stepper motor-stepper motor driver | Georg | Stepper Motors and Drives | 0 | 10-16-2007 04:56 PM |
| servos motor controled by stepper motor driver? | mike10 | Servo Motors and Drives | 1 | 01-03-2005 05:05 PM |
