Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 05-17-2011, 06:37 AM
762x51 is on a distinguished road
New Hermes NHI810 Retrofit
I知 converting my NHI810 to get rid of the original electronics and replacing them with a Gecko G540 controller. I知 also replacing the original stepper motors and power supply. I値l post some photos of the conversion as it progresses.
Here are the parts I知 using and links to suppliers:
Gecko G540 controller: Gecko G540
E-Stop switch: Emergency Stop Switch
Spindle Motor relay: 48V Relay Kit
48 VDC Power Supply KL-350-48 48V/7.3A 110V/230V: Switching Power Supply, Keling Technology Inc, USA
Limit Switches # 7193K2 : McMaster-Carr
Stepper Motors STP-MTR-23055: STP-MTR-23055 Products
Stepper Motor cable: STP-EXT-020: STP-EXT-020 Products
PC Software: MACH3:
ArtSoft USA - Home of Mach3 and LazyCam
Cost to date:
Gecko G540: $265.00
E-Stop switch: $19.50
Spindle Motor Relay: $8.75
48 VDC Power supply: $49.95
Limit Switches: 4 @ $6.10 = $24.40
Stepper Motors: 3 @ $30.00 = $90.00
Stepper Motor cable 3 @ $14.00 = $42.00
MACH3 Software license: $175.00
Misc. shipping, terminal strips, etc. = $50.00
Conversion cost to date: $724.60
Alternate is the Q1 conversion for $2,850 + software:
http://www.q1engravers.com/pdf/Nhi810_Retrofit_2010.pdf
I致e attached a copy of the wiring diagram and I値l post some photos of the conversion later today. It痴 not finished but you値l be able to see what I致e done so far.
Any suggestions would be appreciated.
Regards,
Orin
Old 05-17-2011, 02:52 PM
underthetire is on a distinguished road
I'm watching this post! Our hermes needs the same thing.
Old 05-18-2011, 07:09 PM
Here are some photos of the retrofit to date. As you can see, this is still very much a work in progress.
Limits for the X axis are installed and the original +Z limit is being reused. You may notice I have drilled a hole in the top of the Z axis enclosure.
I needed to get to the 2 set screws in the Z axis cam and drilling a access hole made getting to them much, much easier.
Still need to come up with a good way to mount the Y limits.
I think I'm going to abandon replacing the original power supply because the new steppers have plenty of torque using the existing 24 VDC supply. New motors are much quieter than the old ones and the axis movement smoother.
Wiring is a rat's nest now and I'll be adding another terminal strip to help clean it up.
ID:	134454   Click image for larger version
ID:	134455   Click image for larger version
ID:	134456   Click image for larger version
Old 05-23-2011, 06:56 PM
I've gotten a little more accomplished - Mounted the Y+ and Y- limits and the Y+ Home switches. They were mounted on the right Y axis linear slide cover and there needs to be another mounting screw added at the rear to prevent the cover from moving.
I'll be mounting the X- Home switch in a similar fashion - gang mounted with the X- limit switch.
ID:	134776   Click image for larger version
Old 05-28-2011, 01:41 AM
Retrofit is finished - Now it's time to learn MACH3.......
Here are a couple of photos of the final wiring and a PDF file of the schematic.
ID:	135095   Click image for larger version
Old 10-04-2011, 10:28 PM
cokita86's Avatar
cokita86 is on a distinguished road
I see that you know a lot of the new hermes nhi 810, i just bought one in ebay.. it came bu when i turn it on only appears a green screen.. nothing more, please help me
Old 10-05-2011, 05:10 PM
I cannot help you as I never used the original controller because it wasn't working when I bought the 810.
Need Help!- Hermes NHI 810 762x51 Engraving Machines 16 11-17-2011 03:30 PM
Need Help!- New Hermes Gravograph nhi 810 Ziekte Engraving Machines 4 05-08-2011 07:14 PM
Need Help!- New Hermes VG3400 underthetire Engraving Machines 7 02-09-2011 02:05 PM
New Hermes 810 Y-axis help! Urkslaven Engraving Machines 0 12-28-2009 06:53 PM
Newbie- New Hermes nhi 810 engraver hopeitworks Engraving Machines 1 08-15-2009 05:02 PM
