Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 04-16-2011, 02:23 AM
J514's Avatar
J514 is on a distinguished road
Help with NEWLYDRAW
Hi All,
I have finally figured out how to get a WMF to cut by putting it in Corel and exporting it as a DXF file and importing it into newlydraw, the problem I have is when I export the corel file I make all the lines from hairline to none and when its in newlydraw the laser still goes over the cut line twice and not once like I want, can anyone help me fix this?????
Im cutting fine .5mm hips and two passes is too much.
Cheers and thanks all.
Help with NEWLYDRAW J514 Laser Engraving & Cutting Machines 8 04-17-2011 09:07 AM
Newlydraw problem froggygeorge Laser Engraving & Cutting Machines 16 02-04-2011 12:51 PM
Need Help!- Looking for Newlydraw installer carrammba Laser Engraving & Cutting Machines 1 01-04-2011 09:27 AM
Need Help!- Looking for the NewlyDraw installer. Mrebeiro70 Laser Engraving & Cutting Machines 0 10-18-2010 03:31 PM
Need Help!- NewlyDRAW - Cut In / Cut Out LuAn Laser Engraving & Cutting Machines 2 04-06-2009 12:36 PM
