Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 02-08-2011, 09:55 AM
cainam is on a distinguished road
Engraving Material Bowing
We just purchased a used New Hermes Vanguard 3400 and are trying to figure this sucker out. Our biggest issue at present is that when we clamp the material to the table it either bows in the middle due to the pressure of the clamp, or we don't tighten the clamp enough and the material moves. There doesn't seem to be a happy medium.
Does anyone have any tips for getting engraving materials to lay flat on the table? I tried folding up a piece of printer paper and putting that underneath to give some resistance to the bowing, but unless I used just the right amount it would just bow the other way. Any help would be appreciated.
Old 02-08-2011, 10:19 AM
Tweakie's Avatar
Tweakie is on a distinguished road
For my machine I either use double sided sticky tape for the 3mm and over or a vacuum table for the 1,5mm and other thin stuff.
Tweakie.
CNC is only limited by our imagination.
Old 07-18-2011, 11:55 PM
Dave's_Not_Here is on a distinguished road
Get yourself some MultiMat. Johnson Plastics has the best prices. Works like a charm and no need for clamps!
Double sided and will last a long, long time. You can't go wrong!
DNH
Bowing aluminium when pocketting Lugy General Metalwork Discussion 11 10-28-2010 06:16 PM
My base is bowing guru_florida DIY-CNC Router Table Machines 2 05-23-2008 01:37 PM
Keeping the cutting bed from bowing? matt888 JGRO Router Table Design 15 01-07-2008 03:11 PM
Engraving material Buzz9075 Engraving Machines 4 09-01-2007 10:43 AM
Engraving Plastic Sign Material Dingo745 Engraving Machines 11 08-17-2007 06:39 PM
