Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 02-04-2011, 01:34 PM
o1dakota440 is on a distinguished road
engraving a logo
can someone here convert a file to a .nc file for me? i have a logo i would like to engrave on the front of an aluminum case, i tried importing the bmp to mach 3 but it just locks up. i also have the file in .svg and .eps so if someone ould give me a hand with this i would be very thankful.
Old 02-05-2011, 02:42 AM
Tweakie's Avatar
Tweakie is on a distinguished road
You need to post the file.
Tweakie.
CNC is only limited by our imagination.
Old 02-05-2011, 05:11 PM
i got it into a dxf file that i can import into mach3. but i cannot figure out how to set my starting point or zero. i usually like my xy zero to be center of the machine and my z zero is the top of my work piece. wha can i do from here?
Old 02-05-2011, 07:19 PM
ok i got it centered in rhino (xy). now when i import it into mach, it will engrave in the right spot. it just will not lift the tool when it moves from on part to another, so it is cuting a line from one part of the logo to the other. what do i do to set my tool depth, my work piece hieght and my safe z?
also how do increase the feed rate?
Old 02-06-2011, 01:08 AM
Tweakie's Avatar
I think your best bet is to use LazyCam which is included with and part of Mach3. You will be able to set tool zero and depth of cut as well as safe Z etc from there.
Tweakie.
Old 02-06-2011, 02:06 AM
i thought i was using lazy cam. where or what screen do i need to be on to set the tool depth and safe z?
Old 02-06-2011, 02:34 AM
Tweakie's Avatar
The tabs at the bottom.
Tweakie.
Old 02-06-2011, 04:04 AM
thank you so much. i will try it out tomarrow
Old 02-06-2011, 04:44 AM
canwong is on a distinguished road
Transform it into CAD or CAM file first.
Regards.
www.gskcnc.cn
3D Logo johnno10 Vendor Discussion 2 06-16-2010 06:07 AM
MGi Logo MysticMonkey Fanuc 0 11-03-2009 09:11 PM
Help doing logo procnc Vectric 2 06-03-2008 08:38 PM
RFQ Logo buckkillr8 Employment Opportunity 17 04-16-2007 11:01 PM
Need help with Logo CRFultz SheetCam 13 05-01-2005 06:23 PM
