Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 12-15-2010, 02:41 PM
dano9700 is on a distinguished road
Find center of circle
I mainly engrave jewelry, so one problem I've repeatedly run into is finding a way to get my engraving perfectly centered in a circular area. Alot of engravable charms and pendants are round and roughly coin-sized, so even a small deviation from the center is very noticable.
My question: does anyone know a good way to pinpoint the center of a circle? I usually end up taking 15 minutes adjusting and estimating and still sometimes the engraving looks off center.
Old 12-15-2010, 06:16 PM
christinandavid's Avatar
christinandavid is on a distinguished road
If you could get an appropriate sized three-jaw chuck mounted to the machine you could find the centre using a blank disc. As long as you have a way to mount this chuck in the same position each time, you will have a definite machine co-ordinate for the centreline, regardless of the job size.
DP
Old 12-15-2010, 06:32 PM
Torsten's Avatar
Torsten is on a distinguished road
If you have some visual edges to pick up you could Draw them right into your Cad file.
Then use a Wiggler as your first Tool and have the Program position it at the quadrant points of your shape, like stop at the top center then bottom center then Left and right respectively.
Each stop would give you a chance to make small corrections to your offsets.
A visual check with a wiggler can get you to better then .005" if done carefully.
Old 12-15-2010, 07:19 PM
chich2 is on a distinguished road
Mach 3 has an awesome circle center finder in it's wizzard tools. You touch your tool or touch probe on a point on the circle, "press point A" jog the machine to another point on the circle "press point B" then jog the machine to a third point on the circle "press point C" then you have 3 stored points around the circle. "Press Go to circle center" and the software triangulates the center of the circle center and jogs the machine to that exact piont. Then if you want you can even Zero all your axis and make that your reference point.
I use this method all the time. I cant remember the last time I have used a dial indicator or finger dial to find the center of a circle.
Hope this helps,
Chich
find center point of circle Farzaneh_2010 G-Code Programing 14 10-10-2010 02:34 AM
How do u find the center by.... Bluegillman HURCO 8 06-03-2008 03:08 PM
How to find this center? ZipSnipe General Metalwork Discussion 5 01-11-2008 03:30 PM
How to find center taps on 8 wire stepper Rodm1954 General Electronics Discussion 2 10-23-2007 09:38 AM
Find the center of a circle Hobbiest WoodWorking 7 01-27-2004 11:24 PM
