| Engraving Machines Discuss Engraving Machines here. |
I need to engrave a picture and some text onto 6x9 inch glass squares. So I was thinking if it would be possible to do on a conventional CNC mill. 1. has anyone done it? is it even worth trying? 2. what is the spindle speeds needed for the occasion? 3. what kind of endmills / bits do I have to use for that? 4. what kind of depth of cut are we talking about while engraving a glass? |
| Hi Zaebis, I'm also trying to learn glass engraving at the moment. Like Tweakie said, a burnishing attachment is your best bet, along with a rotating diamond cutter. Since the attachment is spring loaded, you don't have to worry about depth/pressure settings, just give yourself a few mms leeway and the spring does the rest... As for the speeds, I'm still working that out myself, but all the recommended rpms I've heard are around the 10k-20k range. Still, I'm having trouble getting consistent results unless I use a very low feed rate, like 2-4 mm/sec. Faster than this, the cutter misses alot of areas. I'm not sure if my cutter is bad or if the glass I'm burnishing is low quality, or maybe a combination of both. Maybe someone has some additional advice on this? |
| Dano, It is usual to coat the glass with a thin application of a wetting agent or detergent just prior to engraving. (otherwise any surface finger marks can cause problems). Tweakie.
__________________ CNC is only limited by our imagination. |
| I've got that covered--my machine has a water circulation system that keeps a steady flow of water on the engraving area. Actually I wonder if I'll get more consistency without the water, since the burnisher seems to glide right over areas without affecting the glass. |
| using the indexer to engrave glass | woodman08 | LOGILASE 9060/12080/150120 / 250120 cnc lasers | 0 | 03-07-2010 06:23 PM |
| for Metal Engrave | Jim Burns | Laser Engraving & Cutting Machines | 2 | 11-07-2008 10:21 PM |
| WHAT THE BEST METAL TO ENGRAVE IN? | hillco148 | General Metalwork Discussion | 1 | 07-15-2008 02:45 AM |
| Does it have hobby-spindle to engrave on metal surface? | Mongkol | General Metalwork Discussion | 0 | 06-26-2007 12:04 AM |
