Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 10-14-2010, 12:50 PM
adrianhdezch's Avatar
adrianhdezch is on a distinguished road
Unhappy focal lens
I own a chinese laser machine and I need to replace the focal lens. However, the lens holder is not a clamp that can be easily removed to replace the lens. The lens holder in this machine is a screwed in holder which is very tight and I suspect is glued in.
Can some give me an advice?
Regards
Old 10-15-2010, 05:30 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Typicaly lenses are held in assemblies with a threaded ring which has two slots on its circumference. These slots are opposite each other and you use a special wrench to loosen it- can't remember what it's called.
I have used an old vernier caliper before to do this- use the internal measuring bit of the caliper but be very careful not to slip or you'll scratch the lens.
This is assuming the assembly is as above- if not sorry for the bother.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 10-18-2010, 12:58 AM
kewlkiwi's Avatar
kewlkiwi is on a distinguished road
Did you get a short steel rule (to set focus with) with your machine?
That may work (it did on mine)
Bob
DUAL FOCUS LENS (bifocal lens) bibi Laser Engraving & Cutting Machines 5 03-17-2009 05:03 PM
Focusing lens deon Laser Engraving & Cutting Machines 4 02-04-2009 06:18 AM
Problem- LENS SIZES SHADOW042 Laser Engraving & Cutting Machines 0 08-05-2008 09:29 PM
Looking for some Help Optic Lens tklock Laser Engraving & Cutting Machines 9 03-27-2008 05:39 PM
Where to buy lens? medved Mechanical Calculations/Engineering Design 5 12-30-2005 02:49 AM
