Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 09-12-2010, 08:16 PM
granth3 is on a distinguished road
klic n kut with a dremel?
Hello!
I don't know if anyone has any experience with a klic n kut but i have an opportunity to buy one for really cheap. I would like to mount a Dremel to the arm and use it as a engraving machine.
Any ever tried anything like this?
Thanks,
-Grant
Old 09-13-2010, 02:47 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Hi Grant,
These are nice machines but I doubt they have the motion torque or rigidity to handle a dremel / spindle.
It would be fantastic for fitting a small laser tube though.
Tweakie.
CNC is only limited by our imagination.
Old 09-13-2010, 04:20 PM
Thanks for the info.
I wonder if i run it at slow feet rates it it would help.. Sometimes you don't know till you try... or fail haha
Thanks,
-Grant
Old 09-14-2010, 12:39 AM
Tweakie's Avatar
Spot on Grant - you never know until you try.
Good luck,
Tweakie.
Dremel Housing Fairshotguy Mechanical Calculations/Engineering Design 3 07-16-2010 07:45 AM
Using a Dremel shearder DIY-CNC Router Table Machines 4 09-12-2009 04:57 PM
Quieter Dremel chazmtu DIY-CNC Router Table Machines 2 04-18-2008 05:29 PM
What can I use instead of a dremel? david90 DIY-CNC Router Table Machines 1 12-11-2007 01:50 AM
Dremel toolholders fireballcnc DIY-CNC Router Table Machines 0 09-12-2007 09:46 PM
