Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 09-04-2010, 08:19 PM
granth3 is on a distinguished road
Questions!
Hello!
Thanks for taking the time to read my post. I was wondering what the depth of a typical engraving is? Is it deep enough to pull letters off if resin or a casting material is poured on it?
Thanks in advance for your help!
-Grant
Old 09-05-2010, 05:28 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Grant,
If you are using a spindle and the letters are big enough to be able to use a flat bottomed endmill style cutter then you could achieve excellent results with casting letters.
However;
The typical engraving points only have a 0.004" flat on the bottom so the surface finish on any letters cast this way would be ridged.
Lasers also have a typical spot size around 0.004" and again ridges would be present on the casting unless the laser could be accurately set (perhaps out of focus) and the speed kept at a constant velocity to preserve depth.
Tweakie.
CNC is only limited by our imagination.
Old 09-05-2010, 01:21 PM
Thanks for your response!
I am looking to have mostly rectangular shapes. I was hoping to make a mold to take surface detail. It would be a mini brick wall.
Any engravers in the southern california area?
Thanks,
-Grant
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 03:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 12:40 PM
11 T Questions hackmeister Fanuc 0 03-03-2010 08:59 PM
More questions extremecanvas Commercial CNC Wood Routers 1 10-03-2006 07:30 PM
New guy questions tr4252 General Metal Working Machines 17 04-25-2006 04:44 PM
