Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 03-16-2010, 04:09 PM
Frogblender is on a distinguished road
Engraving Anodized Aluminum: chipping?
Howdy... I'm trying to engrave onto anodized 6061 using a .006" 15° carbide engraving bit @ 6000RPM @7ipm and around .001" DOC.
The anodizing is NOT hard anodized. In the picture, the letter "l" is .055" tall. You can see a fair bit of chipping between letters "a" and "l".
Any idea how to reduce the chipping? It seems the anodized black version of the same part is less susceptible to chipping than the blue part shown in the picture.
Without a microscope, it looks "not bad" - a tad fuzzy. But I want perfection.
Old 03-16-2010, 05:01 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
I've never had any luck engraving anodized finishes. I was looking forwards to it before I had the anodizing line setup, but several tries on my on anodizing has never been successful. Mine looked a fair bit worse than yours.
Any amount of anodizing is harder than the bare aluminum, and I think you will have this chipping regardless of what you do. I may be wrong though...
Paul
Old 03-16-2010, 05:19 PM
M250cnc's Avatar
M250cnc is on a distinguished road
@ a depth of .001" you are only cutting the anodising
So you could go deeper with a more pointy cutter & drop the feed to 2" min & work your way up to find your max feed
Phil
Old 03-16-2010, 05:50 PM
Phil
With a 15° cutter, 'tis about as pointy as one can get. I did try 10° (actual more like 12° when I measured it) bits, but the tip lasts "seconds".
Going deeper causes aluminum burrs. It also seems to cause more chipping.
Man, nothing is easy.
Am I wasting my time trying to engrave these on my mill? Should I just send it out for yag or CO2 lasering? I have a CO2 laser sample (done on one of them cheapo chinalasers), but the lettering seems more "dull" than the lettering done with the cutting bit.
Old 03-16-2010, 09:42 PM
Gold Member
RomanLini is on a distinguished road
If that is a 15° point and 0.001" depth the line width should be only about 0.001" but your line width looks about 0.007" or 0.008" (based on 0.055" height of the l) so you have 6 or 7 thou runout! No wonder it is mashing the finish.
Try cleaning the collet to improve runout or rotating it, or using a new collet or new bit. Then test the engraving with a magnifier to see your runout.
And 6000 RPM sounds way too low for fine engraving.
Old 03-16-2010, 09:52 PM
It's a flat-bottomed bit with dia .006" - add to that my ~.0005" of runout,and your guess of line width is quite accurate.
6000rpm is all she can muster I do have a 30000rpm airspindle - perhaps I should try it. I've been avoiding it because of the huge amount of air it eats, with corresponding non-stop and defeaning compressor noise.
Old 03-17-2010, 09:10 AM
M250cnc's Avatar
Maybe you have spindle slop
If the runout is repeatable, make sure the cutting edge is at the outermost extreme in the cutting circle.
Runout isn't the problem as you only have a single edge cutter
Is the cutter new, is it quality ?
Phill
Old 03-17-2010, 12:46 PM
Phill
Yes cutter is new; quality is a crapshoot ($20 for 10 from ebay).
After lots of fiddling, reducing the DOC helps alot to reduce both chipping and aluminum burring. In fact, now it looks pretty damn good. The only drawback is now I'm working with fractions of a thou for Z height.
Need Help!- Engraving anodized aluminium-chipping? surfit General Metalwork Discussion 1 11-22-2009 12:20 PM
Need Help!- Engraving anodized aluminium-chipping? surfit General Metal Working Machines 8 11-19-2009 09:53 AM
laser engraving on anodized aluminum ezflowrider Laser Engraving & Cutting Machines 15 06-01-2009 07:25 PM
Engraving anodized aluminum - color fill? Neil_J Hobby Discussion 25 09-16-2008 09:11 PM
Engraving in anodized aluminum fish09 Engraving Machines 6 08-24-2007 04:02 PM
