I use the Thermark LMM-14 in a spray can once in a while on clear anodized alum., works OK. Mostly use it on steel.
Using a 25 watt Mercury Laser-Pro at 100% power and 30% feed.
They have other products that might work better with the alum., but being this is "general purpose" you can use it on various metals and it's quick and easy to use as a I get it in a spray-can.
*One note, after lasering, the best thing I have found to wash the excess spray off is to soak in COLD water for a few minutes and it rinses off nicely. Avoid rubbing the lasered area and NEVER TRY TO RINSE OFF THE EXCESS WITH WARM OR HOT WATER!! this will activate the spray and turn the entire area dark. Good luck!
Don
