Build Thread want to change spindle mount
Results 1 to 6 of 6
Thread: want to change spindle mount
    Jun 2017
    United Kingdom
    Default want to change spindle mount
    ive got a 3040t or what ever they are called and id like to uprate the spindle so i brought a 600w thinking it would be a easy swop little did i relise the 600w spindle id 57mm wide
    so my problem now comes with mounting it to the z axis
    could any one please point me in the right direction to change the mount as mine is a one peice onto the axis picture included
    thanks
    Attached Thumbnails Attached Thumbnails want to change spindle mount-20170817_114312-1-jpg
    Jun 2005
    Default Re: want to change spindle mount
    If that existing mount is say 80mm and the new spindle is 57mm, you might be able to make a sleeve to slide over the spindle, which would then go into the existing mount.
    Russ
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I think his mount is smaller.
    UCCNC 2017 Screenset
    Jun 2017
    United Kingdom
    yes the mount is 52mm
    Jun 2005
    In that case you only have a few options. You could cut the existing mount all the way across at the first outer fin closest to the bearings in the back. Then take a flat piece of 1/4" aluminum and bolt that to what is left of the old mount. Then drill holes in the 1/4" aluminum plate for the new mount that supports the new spindle. The other option is to design and build and entirely new mount assembly including the bears.
    Russ
    Jun 2017
    United Kingdom
    just a bit of a update on this
    tried to take the mount of but it apears its put togeather in such a way with intefernce fit parts etc its a pain so fabrication seems like a no go, so ive took the easy option and order the 52mm sindle but a 400w. thanks for the help
