- Help with output signal for drill
Hello...
I made one fine CNC and is working, but i can't solve one problem
How to start mill/drill (tool for engraving) when I start the code
I should set output signal to ENABLE and then what? Then I have constant 5V all the time on that pin.. Not 0, and 5V after starting program, but all the time
The LPT 25 pin plate is here
http://www.elektrobot.hu/items/1469_1.jpg
2,3,4,5,6,7 pins are for step motors, and I supose that any of the rest should do for drill
please help
- You may not post replies
- You may not edit your posts
Forum Rules
