- Techno Mark Multi4 problem
today i set up to dot peen a job, but when i tested it; i got bad results. I've never had this issue before, but i will explain in hopes someone can lend me a solution from experience.
1st test it engraved properly
2nd test it traveled in y a bit
3rd, 4th, and 5th. test it continued to travel in y a bit until it over traveled. I'm not experienced with this machine, so please give me grace.
i unplugged it, waited a minute; fired it back up with same results. I then created a new program, but still same results.
any help or suggestions would be appreciated, i have several jobs that i need to complete to ship tomorrow.
- You may not post replies
- You may not edit your posts
Forum Rules
