- Need Help!- ep module for vangurad 7200 running FlexiEngrave ver8
i am having trouble setting the Lift height now.
i check the picto on the ep module and arrow up the height i want .50
and hit check then go back to it and it appears right but when i run the job
it defaults to the .19 its set at. How do i change the default to ...........50 instead
of the .19 it now displays.????
thanks for help
I have a slightly used Vanguard 7200 New Hermes machine in excellent running condition with user manuals & cables: EP CONTROL MODULE, CASmate-Pro Windows 98 Software and documentation, two windows 98 computers(primary/backup), vaccum table, vacuum chip collector, numerous cutting tools, Beveler machine, 12" Shear and ScanMaker flat bed scanner to scan in graphic logos. Also have variety of 12x24" lamenated plastic, some brass/aluminum. Retiring after 20 year hobby of making name badges, ada signs, and directional signs. Willing to sell, make reasonable offer.
e-mail: jhanson61@gmail.com
- You may not post replies
- You may not edit your posts
Forum Rules
