- Newbie- Small cutting/engraving for 3mm aluminium front panels
Hi guys,
I'm an electronic engineer, new to CNC, it's quite overwhelming the amount of resources available here! I'm looking to build a CNC machine simply for cutting and engraving front panels of enclosures (anodised aluminium) with a small working area up to 30x20cm. Speed is not much of an issue.
What I'm looking for is some advice from those experiences as to how to tackle this, I'd really appreciate any advice for:
- Would it be better to attempt converting a small milling machine or build from scratch?
- Are there any resource available for a similar machine you may have built
- Any recommendations for motors, spindle or controller
Thank you!
- You may not post replies
- You may not edit your posts
Forum Rules
