- ENGRAVING ISSUE
ENGRAVING ISSUE
hello
i recently change my tube and psu . i have a 50w tube and a 60 w psu.
cutting works perfect ...engraving....not so well ( see pics)
i have checked the belts, motors, mirrors, lens, cables ....still nothing
on x swing the "effect" is in both sides, on y swing , the same only vertical, unilateral left/right , the same left or right
this happens only at speed higher than 60mm/s
i have read about voltage tickle ......a jumper on my laser control board or something like that....that is the only thing that i haven`t tried
thank you
- ENGRAVING ISSUE
- You may not post replies
- You may not edit your posts
Forum Rules
