I do a lot of engraving in aluminum and I'll tell you what I know,, it will get you off to a good start. I use a 1/16in ball endmill, carbide, 2fl, you want to go with 2 flutes in aluminium, carbide for sure. I run them from 0.015in to 0.005in ten thou deep is good, at 6-10 ipm. the Angles pointy bits will make a thinner or thicker line, but that also varies depending on how deep you go with them, it's nice to have a couple different angles, 45, 90, 60 are good to have, as some will work better depending on the spacing of the lines like depending on the font for example. Search ebay for a guy called "Drilllman1" he has great deals on little bits, I get most of my engraving bits and 1/16in balls from him. The 1/16in ball em, 2fl, is great, it's a really nice bit to engrave with. Good luck.
