Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-20-2010, 02:01 PM
tr4252's Avatar
tr4252 is on a distinguished road
Write knife grinding program
I make custom knives, and recently built a two axis (X & Y) grinder to grind the hollowed portion of the blades. Though it seems simple enough, I am not doing as well as I would wish.
I need a program or programs which will enable the grinder to follow the curvature of the lower blade edge and result in a uniform thickness at the cutting edge area.
I think this would be a rather simple task; I have been successful in approximating the desired effect by means of a series of straight tool path moves, but would prefer a more professional and efficient approach.
Any and all ideas and offers would be appreciated. I will of course be willing to pay for the service.
TomR
Old 02-20-2010, 02:13 PM
Dualkit is on a distinguished road
It would help if you listed the controller you are using, while G-codes and X,Y,Z coordinates are common to most controllers, M codes and other codes are not.
Old 02-20-2010, 05:32 PM
tr4252's Avatar
Thank you Dualkit,
G code programming of the X and Y moves would be sufficient. This really is a simple undertaking; I'm just having trouble visualizing the geometry and applying it. I would attach an autocad drawing if I could figure out how to reduce it to the maximum file size. The part would move toward the grinding wheel on the Y axis as it traverses in the X axis, to follow the curve of the blade lower edge and produce an edge of uniform thickness.
I'm using an application called Millmaster Pro which I got as a package with a small vertical mill from Microtronics. I model my work with autocad.
The device I built has a couple of NEMA size 23 step motors and linear ball bearings; it has only X and Y movement.
I hope this description helps; I'll try to find a way to attach a drawing.
TomR
Old 02-20-2010, 06:10 PM
tr4252's Avatar
dwg converted to jpeg; hope it shows up OK.
Name:	ST4 BLADE GRINDING-detail for quote.jpg‎
Old 02-21-2010, 11:30 PM
justgary's Avatar
justgary is on a distinguished road
TomR -
You say you are having trouble visualizing the geometry. All you really need is to flip the profile of the blade in both the horizontal and vertical axes and use the resulting curve as your blade's path against the stone.
I have done this on your drawing as a thick red line. If you imagine starting the grinding process with the root of the blade and working toward the tip, you would want the blade to follow the red line from left to right.
Other than that, you shouldn't need much more to make a blade.
The blade you show, however, is not drawn correctly. The edge-on view on the bottom shows the tip having the same thickness as the root of the blade, and yet the profile view on the top shows a drop point. In order to keep an edge all the way to the tip, the blade will get thinner after the hollow grind meets the back of the blade.
Also note that your blade starts with the hollow grind parallel to the edge, but does not stay parallel after the curvature begins. If you really expect that to happen you'll either need a variable diameter stone or a tapered blade thickness (or don't expect the blade to have an edge the whole way).
In other words, for a simple hollow grind on a blade made from a flat bar, the back part of the grind will always be parallel to the edge of the blade. Only tapering the blade thickness or changing the grind radius will allow the back of the hollow grind to get closer to the blade's edge.
Regards,
- Just Gary
Name:	ST4 BLADE GRINDING-detail for quote2.jpg‎
Old 02-22-2010, 12:06 AM
jalessi's Avatar
jalessi is on a distinguished road
Thumbs up
TomR,
Do you have any pictures of your knife grinder?
Thank You
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 02-22-2010, 12:44 PM
tr4252's Avatar
Thank you for your responses.
Below is a photo of the machine right after I got done converting it to CNC. I built it about 3 years ago. The blade blanks are mounted to the block with the toggle clamps which is facing the wheel edge.
TomR
Name:	CNC GRINDER 11-30-09 001.jpg‎
Old 02-22-2010, 02:16 PM
jalessi's Avatar
Thumbs up
TomR,
Very kewl looking machine.
Please post a picture of how it holds the blades.
Thank You
Jeff...
Old 02-23-2010, 07:37 PM
tr4252's Avatar
Sorry Jeff, I have no photos of that. Picture the blade mounted to the block held by the toggle clamps, its side facing the edge of the grinding wheel.
Tom
Old 02-27-2010, 12:23 AM
samhyto is on a distinguished road
Tom,
The biggest problem from what I see is that you have no control of the Z axis which without, changes the thickness of the cutting edge as you move along the length of the blade. The diameter of the wheel would have to be taken into effect as well.
Sam
  #11   Ban this user!
Old 02-28-2010, 10:12 AM
tr4252's Avatar
Thanks everyone,
The way this works is that the grinding wheel must move closer to the centerline of the blade edge as it moves toward the point, to maintain a uniform edge thickness as it curves upward. I had been doing this operation manually on the same machine for a few years, using limit switches and step motors, but no computer control. Then I converted the machine to CNC a few months ago, believing the programming would be relatively easy.
I was having difficulty visualizing the thing from start to finish, so I decided to begin at the end and work my way backwards. This is working pretty good; I wrote a program which simply contained the last pass, backed the blank away from the wheel the appropriate amount, and ran it over and over, advancing the blank .001 per pass. Now all I have to do is write the program to include every move, and wheel dressing subroutines.
I'm grateful to all of you who've offered help with this.
Tom
  #12   Ban this user!
Old 03-03-2010, 08:48 AM
tjones's Avatar
tjones is on a distinguished road
While this can be done more needs to be known of the machine control and hardware capability.
Is the Z axis capable of being programmed to move?
Does the machine handle macro style programming?
What type of dressing routine is needed? (ie: straight or formed)
What control?
I write macro programs for a 5 axis CNC tool and cutter grinder made by Jungner. Since I service these machines in the US I know all their requirements. ( www.jungner.se )
hollow grinding service needed for knife blades alex 850 Employment Opportunity 1 06-16-2008 05:55 PM
How to write a code program to cut threads jjenks NCPlot G-Code editor / backplotter 7 04-21-2008 09:18 PM
Quote for surface grinding hoju1301 Employment Opportunity 11 09-06-2006 10:16 AM
Possible to write variables to a program? Heavy D G-Code Programing 2 08-21-2006 11:08 PM
someone wanna write a program? ljoe1969 DIY-CNC Router Table Machines 2 06-06-2004 07:47 PM
