Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-17-2010, 11:40 AM
KramerTool is on a distinguished road
12000sqft available for component production
Hello everyone,
We have 12,000 square feet availabe for component production. We can design and build automation for injection molding, metal stamping and assembly.
We also have our machining division with the following services:
* Wire, Sink and small hole EDM
* CNC Machining and turning
* 1 off and production machining
* Reverse engineering / Digitizing
* Die design, building and repair
* Welding Tig, Mig, Gas and Stick
* Cylindrical and Surface grinding
* Small stamping production runs
* Robotic tooling/fixture design and building
* Tool steel welding
* Indexable CNC cutter repair
* In-house heatreating
* Sandblasting
* Keyway cutting and broaching
* Millwright repairs in your plant
OUR EQUIPMENT:
EDM
* Sodick AQ535LH (5 axis) wire edm
* Sodick A3CR (4 axis) sink edm with threading capabilities
* Sodick K1CN (3 axis) edm drill (.007” dia. - .118” dia). Up to 12” deep
CNC Machining Centers
* Mazak VTC20B (X40”xY20”xZ20” travels) 10,000rpm
* Mazak VTC41 (X30”xY20”xZ20” travels) 7,000rpm
* Leadwell MCV550D (X30”xY20”xZ20” travels) 6,000rpm
* Cat 40 Speeder head 40,000RPM
CNC Lathes
Mazak Quick turn 15N
* 4,000rpm spindle
* 2.1”dia thru spindle
* 15”swing
* 30”between centers
Daewoo 12L-C
* 3,000rpm spindle
* 4.1”dia. thru spindle
* 22”swing
* 50”between centers
Other Equipment
* 2 heat treat furnaces 2000 degrees Fahrenheit 13” wide x 15”high x 24”deep
* Surface grinding up to 48”x15”’15”
* Cylindrical grinder
* 70 & 110 ton Stamping press
* 50 ton hydraulic press
* David keyseater (broach) 1/16”-1 ˝” capacity
* 8,000 lbs tow motor
* Hardness tester
* Tig, Mig and Stick welders
* Plasma cutter
Inspection
Brown & Sharpe CMM
* Pcdmis CAD++ software
* X18”xY20”xZ16”
* Capable of Digitizing
For more information please visit www.kramertool.com
Huanyang VFD HAL Component scotta LinuxCNC (formerly EMC2) 1 08-31-2011 10:53 AM
Newbie- X3 Component Weights miseree Benchtop Machines 5 11-24-2009 09:34 AM
Fried PLC!!! Looking for this component rainman Want To Buy...Need help! 4 07-17-2009 09:10 AM
component pricing gerrywelshman General Metalwork Discussion 0 05-18-2007 02:31 PM
Component failure len General Electronics Discussion 24 12-10-2005 10:04 AM
