Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-17-2010, 09:41 AM
matt1ga is on a distinguished road
Need quote for small project
Hello All!
I am looking for quotes on a small side project of mine. I need 52 7mm holes and 13 3mm holes per 12" t x 8" w panel. I will need 6 panels. I simply cannot produce consistent results with my drill! The pattern looks like this:
The material is.060 aluminum sheeting. I'm looking for high accuracy. Please respond back to matt@augustasignco.com . Thank you!
My Manual small mill project ZipSnipe Vertical Mill, Lathe Project Log 92 07-14-2010 10:23 AM
Need Help with Small Project mgilbert754 General Metalwork Discussion 1 08-17-2007 11:37 AM
small part need quote 300 pcs. joey1117 Employment Opportunity 5 02-15-2007 08:08 PM
Small project for someone proficient in Rhino bigsmac Rhino 3D 1 01-04-2006 07:18 PM
Looking for side/retired machinist for small project marklongmont Employment Opportunity 1 02-24-2005 09:07 PM
