04-08-2005, 09:49 PM
RFQ - Small production run of aluminum part - European Machine Shops Only Please | | Hi,
Looking for a quote on a small production run of 100 of these. We need a few of them to begin with (less than 10) so that we can inspect the quality of the work, material, check tolerances, etc. and then if all is ok we will need immediately 100 more.
Material can be 6063 or 7075. Whatever you have or can get the quickest. This project is time sensitive so I am looking for someone that can get them done as quickly as possible.
Also, we do require that you sign an NDA & Non-Compete Agreement before we send any drawings to scale and with full measurements. We can supply IGES, para solid, and other formats if needed.
Looking forward to hearing from you,
JD
