Results 1 to 9 of 9
Thread: RFQ.. CUSTOM PIN GAGES needed... Hard Steel, 26.5mm - 60mm by .5mm increments..
    May 2007
    I'm located in northern, NJ. This is what I'm looking for:
    I need to get a price from somebody to make me custom PIN gauges out of some type of hard steel (maybe A2 or even 303/304 stainless)
    -Sizes: 26.5mm thru 60mm by .5mm increments (70 pieces total), each piece 2" long.
    -45 degree chamfer on both ends to cut the sharp corners
    -stamped or laser marked with the size on at least one of the ends
    -Tolerance -.001", +.000"
    See attached Excell Spreadsheet
    Shipped to northern NJ.
    Please PM me with quotes and lead time if interested..
    Thanks!
    Attached Files Attached Files
    Dec 2009
    Its hard to beat Meyer Guage prices. With what you want most if not all will be stock sizes. meyergage.com
    Registered beege's Avatar
    Feb 2008
    All of these are larger than one inch. I don't think they'd be stocked by any gage manufacturer, especially at 2" long. Think hockey pucks.
    Sep 2009
    U.S.A. #1
    We can do them in any of those materials you like. The hardened steel is going to be a expensive venture in just material allone, I think. The stainless steel would probably be the cheaper way to go, but it is going to cost you more to machine then aluminum. I will send you a quote.
    twp
    twp is offline
    Jan 2010
    does any manufacturer stock pin guages in this size already?
    Feb 2008
    Can you tell us how you're going to use these? Might help us "get it". We might be able to suggest ways to bring your costs down.
    Dec 2009
    Quote Originally Posted by beege View Post
    Check page 20 of there catalog. Only a partial list of whats offered. They go up to 3.510 with 2" as a standard length on that page alone.
    twp
    twp is offline
    Jan 2010
    what catalog are you talking about?
    Dec 2009
    Quote Originally Posted by twp View Post
    The one at meyergage.com on the right side of the page there is a link to there catalog.
    1. Replies: 17
      Last Post: 01-15-2010, 03:52 PM
    2. How hard do you press your tormach thru mild steel?
      By CncForMe in forum Tormach Personal CNC Mill
      Last Post: 02-10-2009, 02:57 PM
    3. Replies: 4
      Last Post: 12-08-2007, 11:47 AM
    4. HELP - Hard steel...
      By Coogrrr in forum Open Source CNC Machine Designs
      Last Post: 01-28-2007, 02:49 AM
    5. How hard to make a custom cnc spindle?
      By rlevin in forum General Metalwork Discussion
      Last Post: 09-01-2006, 02:44 PM
