| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
| Hi y'all, I have a need for low-volume production (20-30 units/week) of some plastic parts. Might as well qualify as prototypes, or "repeated" prototypes if you want. No reason to go into further details at this point, I'll just let the pictures do the talking. One thing I need to clarify though, is that I already have these parts and I "only" need those shapes cut in them. ![]() Material is polycarbonate, 1/16" (0.06) thick, size cca 4" by 3" The second image is an acrylic insert that I need created so that it fits that pocket we just cut. I attached a zip file with the models in various formats (download here). I have a set of 1/64" (15 mil) router bits if you need them for those sharp interior corners. I also have a 12x12 fiberboard fixture exactly shaped for the parts if you can make use of it. Please let me know if you can do these, for approximately what cost and, most importantly, how soon can you set everything up to run a first batch. Thank you! Other considerations Location: I strongly prefer someone in the Chicago, IL area for many reasons. Otherwise, it doesn't really matter. Actually, let's put it as a second preference (just a preference!), the location to be within FedEx Ground overnight areas. (zip 60666) As I mentioned in another post,
Hi If you have the time, I would like to get an idea on your USA prices. The parts are quite small and USPS is quite cheap so working from New Zealand may be an option. The small bit may be a problem with most CNC shops and an engraver may be a better option. http://www.marshland.co.nz Cheers Wallace. |
| FXC, We would be very interested in quoting your project even though we are slightly beyond your 1-day ground shipping zone (Akron, Ohio). We have a variety of CNC routers and HAAS mills that would do the job just fine. One question for now, what type of finish are you looking for on the milled surfaces, especially the acrylic? Also, please provide an email address and contact information that I can send a proper quote. Thanks,
__________________ Doug Pryor David Wolfe Design, Inc. Akron, OH www.davidwolfedesign.com depryor@davidwolfedesign.com |
Dear sir, This is arul from, chennai,India. We have the experience of machining polycarbonate and acrylic materials to my korean customers for making some guages. Pls be free to reply back. |
| Hey, I am interested in cutting your parts and am in your next day area. I am in Iowa though zip 50583. Before I could give you a price I would need a little more info. Just milling out the contour in the lid and the shaped hole I assume. As for the insert, is that cutting the whole part or just the shape on the one side? I could fit them in as soon as we figured out price and so on. Thanks Dave Wilt Wire & Fab Ph# 712-661-9613 Last edited by Dave W; 11-23-2009 at 09:40 AM. Reason: forgot something |
| Hi, I can easily machine these at a very reasonable cost and better than 0.003" tollerance using 1/8th dia carbide tooling with spindle speeds up to 60,000rpm on industrial 3axis pcb machine centres. I guess Lead times for first batch could be a couple of weeks inc. postage from Scotland. production time on 30 sets would depend on how well polycarbonate machines. Once programing and tooling setup a batch should take no more than two days to machine, any extra time would be postage. I normally do engraving work, sub-contract and test fixturing work and can machine hard 15.0mm cast acrylic but would have to test some polycarbonate. I understand location is a little far out but if you are interested I'm available and can test/engineer and quote after I have your provisional approval. feel free to check out precision engineering section or www.rjlguitars.co.uk Bobby |
#10
| Small bits from what I see on here is'nt a problem for most shops or mine what soever. But what is a problem is foreigners trying to make USA business's bid pennies to the dollar on jobs that should bring a fair dollar to our own economy. We have high energy bills and taxes so there for we can't quote as low of prices. Bam once somebody "only Americans and Canadians" comes on here with a job that could be a ongoing small production job BAM!! there is some foreigner looking to steel it away from the struggling American business's. HE SAID SOMEONE CLOSE, atleast someone in his own country. I pray he goes American and I beleive he probably will find and go with some one in America, hopefully me, but this job seems to have got alot of attention, so who knows. Anyway what Americans charge is none of you foreigners business, butt out. Americans paved the road to industry and all it's trades that go along with it, you foreigners have no right to try taking work from us. I don't see any foreigners giving me work any American work, why should we give you any more then the rest of the morons allready have.
#11
| I updated the OP but it doesn't show up. Just in case it never will, here are the updates: *** UPDATES *** For anyone having trouble downloading the model files, it's most likely because of JavaScript being disabled in your browser for some reason. For instructions on how to re-enable JavaScript, click here. The package itself in in standard ZIP format and any modern computer should handle that out-of-the-box but, if again for some reason it doesn't, try WinZip. Acrylic insert surface finish: I realize that most surfaces will have a frosted look after machining. Luckily for acrylics, this is not something a butane torch can't handle and as long as it's not grossly rough, I will personally do the flame polishing. Acrylic insert bottom: Yes, the "dimple" in the bottom needs to be done. Unless you have a machine capable of turning it over, this means two runs. Materials: Again, the "boxes" are already made, i.e. they're taken off existing products. The acrylic for the inserts is of a very special type so I'm also sending that in. Interior sharp corners in the "holes" are, of course, to be rounded. However, I prefer a certain sharpness to remain, which is why I mentioned the 1/64" (15mil / 0.4mm) bits that I can send in if you don't have anything so small. Overall precision and tolerances: I cannot provide a requirement here so I'll use layman's specs. Material is pretty thin, pockets are pretty shallow. The insert goes into the milled part and it has to fit. Shape-wise, it doesn't have to be perfect; it's not supposed to be airtight or anything, plus the human eye has its limits, too. Depth-wise, it really has to be flush; running your finger across the edges will certainly show if it isn't. And I'd prefer not having to use shims or glue to "adjust" this. Shop location: What I said above remains. I thank those who've written from outside the USA but for the moment, it's just not practical. If I had to do large volumes AND I simply couldn't find anything here, I would maybe think about sending these outside the USA. I'd save China and some others for another incarnation, though. Prices: By "RFQ", I mean RFQ but not literally. It's more like "Are you there - Can you do it -When". When I saw figures in the sub-$10 range, I didn't know how to take it. I know the economy is bad and everything but I need good work. This is not an invitation to inflate prices but please consider everything before I commit working with you. Thank you! |
#12
| I would like to quote but we are out of your area as far as Fed-ex ground overnight. If you can live with this being a couple of days out I will quote. Thanks in advance Ryan
__________________ Ryan Null Brock Enterprises of VA LLC |
| Need help with Routing plastic | acecnc | CNCzone Club House | 6 | 11-24-2009 08:19 PM |
| PLASTIC STRAW/PLASTIC EXTRUSION PARTS/T8 TUBE | shayla | Product Announcements & Manufacturer News | 0 | 07-21-2009 03:35 AM |
| Need A Quote- Plastic routing (or suggestions) | depewke-cnc | Want To Buy...Need help! | 0 | 08-06-2008 10:34 PM |
| Need Help!- Holding plastic sheets | obsadene | Engraving Machines | 4 | 07-21-2008 01:09 AM |
| RFQ - CNC routing composite sheets | TMaster | Employment Opportunity | 4 | 11-29-2007 05:42 PM |
