Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 11-06-2009, 04:52 PM
AuroraDrvr is on a distinguished road
2D Carbon Laminate
Looking for quotes on the following design.
Units: Centimeters
Tolerance: 0.005cm
Material: 2mm or 3/32" Rigid Carbon Fiber Laminate
Quantities: 1, 5, 10, 20
Turn Around: Open
Forgot to mention this in my other RFQ, I am only accepting bids from United States and Canadian members/companies.
DXF and DWG attached.
Thanks!
Old 11-08-2009, 08:30 PM
Since there doesn't seem to be a whole lot of interest in doing them in Carbon (don't blame 'ya), I am going to open this up to also quoting the same design in aluminum (6061 and 7075).
Edit -
I was informed that my tolerances were a bit tight, so I'm going to go ahead and open the tolerances to .015cm or .006" which ever works better for you. I do however need the hole sizes a close as possible..
Thanks!
Old 11-17-2009, 02:33 PM
universalfab is on a distinguished road
So have you chosen some one to do this job yet, or given up?
Old 11-17-2009, 11:55 PM
Right now the project has been put on hold. We may or may not pick it back up at a future date.
Thanks.
cutting carbon composite laminate juzwuz Composites, Exotic Metals etc 2 03-29-2008 08:43 AM
Flexible carbon laminate? bebson Composites, Exotic Metals etc 1 03-18-2008 07:07 PM
RFQ - Carbon Fiber Laminate Plate CXC_Simulations Employment Opportunity 0 05-31-2007 03:13 PM
Tools for machining solid carbon (not carbon fiber)-more posted camcutter Composites, Exotic Metals etc 5 04-27-2007 07:23 PM
Routing Carbon fibre laminate kong Composites, Exotic Metals etc 38 04-09-2007 12:08 AM
