Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-27-2009, 04:01 PM
Toymanf is on a distinguished road
3000 pieces 304 stainless sheared to length
Hello,
We are looking for a quote for quantity 3000 of 304/304L .1875"x.75" flat stock sheared to .875" long pieces. These are to be used as ballast(added weight) in an injection molded assembly.
You provide the stock.
Please let me know the length tolerance you can provide. (prefer +-.010")
We are currently in devlopment of the product.
There is potential for this to be a recurring order every 3 months and/or larger quantities.
Thank you,
Frank Rodgers
zip code 93422
Old 10-28-2009, 10:01 AM
Michael.lee is on a distinguished road
Frank,
can you send me the drawing for a quote ?
Regards,
Michael
mail@union-mould.com
Old 10-28-2009, 10:21 AM
Dualkit is on a distinguished road
Define sheared. Is saw cut and faced ok? If that can be done cheaply of course. Shipping price a definite concern, do you have a common carrier for shipping. I think I am only 300 miles away which would keep shipping costs low, but I have no shear, which would probably be the cheapest method of cutting these. Why 304 if this is just for adding weight? 1018 would be less than 1/2 price on material cost.
Old 10-28-2009, 10:24 AM
Originally Posted by Michael.lee View Post
Frank,
Regards,
Michael
What do you need a print for? I would think this time China would be non-competitive because of shipping unless communist government subsidized steel is way cheaper per pound.
Old 10-28-2009, 02:51 PM
Hello, thanks for the replies. I have attached a drawing per request.
As far as the material chosen. I need weight and corrosion/rust resistance. If you can suggest a different material which would handle mild exposure to moisture without possiblilty of rusting, I am open to suggestion. As far as the method of cutting these parts, I simply need the parts cut to the requested size. I also figured that shearing would be the most cost effective. Please send me a quote for whatever method you would use. The parts are hidden inside an assembly.
I figured I would leave shipping out of the equation. If you would like to quote shipping, by all means do, but please have it seperated so that I can evalute the quotes per part.
If I end up with a California supplier, I will most likely pick up the parts as my brother travels the state a fair amount.
Thank you
Frank Rodgers
Old 10-30-2009, 03:40 PM
I wanted to clarify that these pieces simply need to be cut to length. The method by which they are cut is not important.
I would like to maintain + or - .010" on length.
Thank you for the replies so far.
Frank Rodgers
Old 11-01-2009, 06:33 PM
kccrusher is on a distinguished road
Frank,
We can shear to that tolerance, but that's not a size of 304 we stock. I will get a quote to you tomorrow. We're in CA, too, 95519 and can provide a sample, if needed.
Old 02-05-2010, 10:09 AM
TRIMI is on a distinguished road
are you still need to shered this parts I'm wichita ks,send me a file and al do it for you.
tra757@cox.net
Looking for someone to cut some pieces for my DIY ClockMaster DIY-CNC Router Table Machines 8 10-31-2009 07:31 AM
Need A Quote- RFQ - Custom Partially threaded socket head screws in stainless - 1000 pieces RECustom Employment Opportunity 7 01-29-2009 01:35 AM
RFQ: Lasered stainless pieces. mrjake22 Employment Opportunity 2 06-20-2007 07:12 AM
RFQ- Hub pieces pinkerton5 Employment Opportunity 13 01-28-2006 09:41 AM
How much unsupported length before stainless will flex? phantomcow2 DIY-CNC Router Table Machines 12 01-16-2006 11:26 PM
