| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I have a need for a rocket nose cone turned on a CNC lathe. Rationale: While nose cones can be turned easily on a lathe, this particular design follows a precise mathematical formula to make it low drag aerodynamically. Material: hardwood and balsa. Can be planked, but in no more than 4 pieces. Quantity: 2, 1 of each material (identical in dimensions). General dimensions: Approx. 17 inch in length and 2.8 inch in diameter. The cone has a shoulder, which fits inside the airframe. Shape: nearly conical, but not quite (technically called a von Karman). I can provide a .dwg or .dxf file. Also, I can provide an Excel file with X,Y coordinates, in either imperial or metric units, and in just about any level of granularity required. A Houston machinist would be a plus, but not required. Greg |
| Hi Greg, This is Jim at Universal Precision Machine, please put up your dwg. or dxf. file, either will do for me. I can't say anything until I see what you want, I appreciate and look forward to doing business with. |
| Hello Jim. This is a preliminary drawing. The cone part is correct but I will need to determine the shoulder OD tomorrow. Please let me know if it makes sense or not. Greg Last edited by GregGleason; 10-20-2009 at 09:41 PM. Reason: Upload File |
| I have the final drawing with a few minor changes. This is an explanation of what is what: NoseConeVK_FinalFull.dwg - Full scale AutoCAD drawing (2008) NoseConeVK_FinalFull.dxf - Full scale .dxf NoseConeSmallVK_Final.dwg - Half scale drawing w/ dimensions NoseConeSmallVK_Final.pdf - Plot .pdf of half scale drawing NoseConeVK_FinalFull-Model.jpg - Simple .jpg of the nose cone profile NoseCone_vonKarman2.scr.txt - AutoCAD script to create the nose cone (half) PLine Greg |
| Tags |
| rfq nose cone |
| Cone Cutting in 15 mm mdf | SuYoG | FAQ of CNC Machine building | 3 | 12-16-2010 04:54 PM |
| What is spindle nose? How do you know exact size SPINDLE NOSE? A2-6, A2-8 | cjchands | Vertical Mill, Lathe Project Log | 9 | 11-08-2010 11:00 AM |
| Bull nose or Ball nose | jcnewbie | Mastercam | 14 | 02-21-2010 06:35 PM |
| Need Help!- Flattening out a cone ??? | Mr. LocoMartin | BobCad-Cam | 9 | 04-09-2009 10:04 PM |
| I need help milling a cone! | dynoman | CNCzone Club House | 1 | 01-21-2009 03:56 PM |
