Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-15-2009, 03:35 AM
levelzero is on a distinguished road
Small Steel Parts
I havn't had a lot of luck finding a local shop to supply these so I'll try here. I've included a sample but if it works out well then I will be requesting 10-50 different designs as things progress.
Material: .375" 1018, 1020 or whatever is handy. If using CRS or P&O then facing is not needed.
QTY: 25,50,100
Tolerances: .005"
Shipping: ZIP 98295
Old 10-15-2009, 07:21 AM
captainDL is on a distinguished road
PM sent! Thank you!
Old 10-15-2009, 04:06 PM
dstryr is on a distinguished road
PM sent. Thanks for the opportunity
Dennis
Creations Unlimited Machining Inc.
Morgan Hill, CA
Old 10-15-2009, 05:03 PM
JimV is on a distinguished road
Hello
You might want to contact this company. They seem to specialize in what your looking for.
http://www.dtprofab.com/
484 EZ STREET PRESCOTT, AZ.86301
PHONE 928.776.4129 FAX 928.776.2405
Old 10-15-2009, 07:46 PM
joe sampson is on a distinguished road
QUOTE
SENT A P.M. QUOTE THANKS JOE @ TUSON ENTERPRISES LLC.
Tuson enterprises
Old 10-16-2009, 09:03 AM
Wrath Machine is on a distinguished road
request for print
Yes Sir I am interested in the work; would you please send or post the file in Adobe format?
Thanks,
David
email: wrathmachine7@yahoo.com
Old 10-17-2009, 07:35 AM
deere_x475guy is on a distinguished road
No dimensions
I didn't get any dimensions when I viewed the drawings. Am I missing something?
Old 10-18-2009, 01:20 PM
wdwrd68's Avatar
wdwrd68 is on a distinguished road
Hello I sent you a PM Thank You jeff@jnsmachine.com
Old 10-19-2009, 09:25 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
For reference - is the ID supposed to be 1.4?
FWIW - open up the tolerance a little and save huge dollars.
www.integratedmechanical.ca
Old 10-19-2009, 11:05 PM
To all who have sent PM's so far, thank you. I've been busy this week and am still collecting/sorting through the various quotes.
For those that asked for a drawing with measurements I've including a jpeg so everyone should be able to view the it with no problems.
Care to explain? I figured 0.005" was fairly loose.
  #11   Ban this user!
Old 10-19-2009, 11:06 PM
Opps forgot the file
  #12   Ban this user!
Old 10-19-2009, 11:09 PM
universalfab is on a distinguished road
In my opinion .005 is plenty loose enough of tolerance and we have no problem at all here at Universal Precision Machine of getting .005 tolerance's or even tighter tolerances of .0009 with our mills and even tighter tolerances than that with our turning operations. Please Level Zero give us the oppurtunitty to make and manufacture your parts, you will be completely satisfied with our workmanship and will get a high tolerance part at a low price and quick turn around time . I already sent you a quote, so please if you have'nt given us a look please do. And any questions please just let us know, we are very willing to work with you anytime.
Jim at Universal Precision Machine
Need Help!- Accurate Small Hole Milling in 15-5 PH Steel yaji63 General Metalwork Discussion 5 01-02-2009 04:05 PM
Drilling small holes in Die steel drk General Metalwork Discussion 1 08-13-2008 02:59 PM
Need A Quote- RFQ for steel parts 98vert Employment Opportunity 9 03-04-2008 04:02 PM
Small end mills feed speeds for 1mm steel paulr4 DIY-CNC Router Table Machines 12 08-13-2006 08:29 AM
RFQ - small mild steel turned and drilled parts mcmmach Employment Opportunity 8 07-28-2005 10:37 PM
