Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-18-2009, 07:19 PM
fullspeceng is on a distinguished road
Simple CNC Foam Cutter job
I need someone with a high tolerance CNC foam cutter to make a simple part for me.
Please quote 2 pieces of this foam cutout per PDF drawing. All dimensions
in inches. It's basically a 23"x15"x3" block with a V cut out in the
middle.
Please make this to as high tolerance as possible (better than .01" on
all dimensions) because this is being used for scientific testing.
Slight radius on the V bottom is ok but make the angle as close to
153.55 degrees as possible.
Use as low density foam as possible but it still needs to be
relatively durable and crush resistant. It also needs to be stiff
with no deformation. I was thinking something like coated styrofoam
but leave that to you because I don't know much about foam.
Also if it is not possible to make the V shape cutout, simply make it
in two halfs (split down the middle) and glue it together.
Send me a PM if you can help.
Old 09-19-2009, 03:29 PM
DragonXtreme's Avatar
DragonXtreme is on a distinguished road
PM Sent
Architectural - Prototype - Modeling - Mold / FrogMill - ScanTech 3D Laser - ArtCam Pro
Foam - Composites - Hardwood (www.dragonxtreme.com)
Hot Pin Foam Cutter damae CNC Wire Foam Cutter Machines 3 01-24-2009 08:40 PM
Build a cheap, SIMPLE, CnC foam cutter. moreil CNC Wire Foam Cutter Machines 51 01-04-2009 09:09 PM
Simple foam cutter venomx999 CNC Wire Foam Cutter Machines 1 02-15-2007 12:20 AM
My first CNC! soon to be foam cutter nikolatesla20 CNC Wire Foam Cutter Machines 8 08-06-2005 02:48 PM
Foam cutter paulried CNC Wire Foam Cutter Machines 4 10-30-2003 04:58 PM
