Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-02-2009, 02:45 PM
SatanKlawz is on a distinguished road
Need a Quote....
I need a quote on 2 parts made of steel or high strength aluminum. These will be the sides of my home built router and I need 2 of these. Drawing is in MM and would like quotes for material thickness in both 1/2" and 3/4" materials. Height is 152mm and the length is 1300mm. You can download the .DXF file and open it in pretty much any cad program and check the dimensions. There are 2 sizes of holes and neither need to be tapped. The holes that are grouped in 4's are all 5mm dia. and the holes that run the length of the part are 5.1mm. dia.
Old 09-02-2009, 03:29 PM
*Registered*
cncjunky is on a distinguished road
Originally Posted by SatanKlawz View Post
I need a quote on 2 parts made of steel or high strength aluminum. These will be the sides of my home built router and I need 2 of these. Drawing is in MM and would like quotes for material thickness in both 1/2" and 3/4" materials. Total length should be around 1300mm if I remember correctly.
Could you post a picture of the drawing? And could you post it in IGES ?
Old 09-02-2009, 06:00 PM
There ya go... I just took a screen shot.
mfg quote MBG General Metalwork Discussion 15 07-30-2009 03:36 PM
Need A Quote- need a quote leehguer Employment Opportunity 3 11-21-2008 10:03 AM
Quote and Multi-Quote JoBwan Test Forum 0 02-23-2008 05:58 AM
How to quote a job Shotout General Metalwork Discussion 26 08-20-2007 08:14 AM
how to quote? qmas99 CNCzone Club House 5 10-04-2005 01:55 AM
