Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-20-2009, 10:30 AM
Charlie Gary's Avatar
Charlie Gary is on a distinguished road
CNC Programmer/Machinist In Seattle/Tacoma Area
I am an experienced cnc programmer, machinist and set-up person. I have spent the last thirteen years working for a machine shop specializing in wind tunnel models, programming and machining complex parts and shapes. Along with wind tunnel and hydro tank models, we designed and machined many different types of compression molds for various companies in the watersports industry. I have experience machining a wide range of materials, from 1.25lb. Styrofoam all the way to High Speed Steel. Resume, pictures and references provided at request.
Later,
Charlie
Old 08-25-2009, 12:09 PM
carlybg is on a distinguished road
Hi Charlie,
Do you have experience with Swiss Machines?
Thanks!
Old 08-25-2009, 12:46 PM
Originally Posted by carlybg View Post
Hi Charlie,
Thanks!
I won't lie. My swiss experience is limited to a passing knowledge of how they work and watching cuts through the window. I have not yet programmed a swiss style lathe for money. How much learning curve (time-wise) are you willing to put up with? I don't think it's fair to charge for incompetence, so in an instance like this it would probably be more fair to charge a set rate and if it takes me ten times too long to create usable code, that's my problem, not yours.
Sincerely,
Charlie Gary
Later,
Charlie
Old 08-27-2009, 11:08 AM
Hello again Charlie,
Do you have experience with a 7 axis machine?
Thanks!
Old 08-27-2009, 01:35 PM
Thanks!
I wish I could say yes, but I don't. I am envisioning a mill/turn center with main and sub-spindles, two turrets and live tooling, though. Did I guess correctly?
Sincerely,
Charlie Gary
Later,
Charlie
Machine scrap yard in Seattle area? Darren_T DIY-CNC Router Table Machines 9 05-14-2011 04:16 PM
Looking for someone in the Seattle/Eastside area nosplinters Mentors & Apprentice Locator 7 08-26-2010 10:11 PM
Job Opening CNC Machinists needed in the Seattle Area! Volt Bothell Employment Opportunity 1 06-09-2008 09:16 AM
Looking for CNC machinist/manual machinist in detroit metro area Runner4404spd Employment Opportunity 4 11-12-2007 12:11 PM
Anyone in the Seattle area that wouldn't mind showing me a CNC Mill in action????? nosplinters Benchtop Machines 8 07-02-2007 09:30 PM
